How to keep GPIO low at power on reset stage?
1,228 次查看
hubertwu
Normally, GPIO default pull-up which cannot be changed by configuring register.
If I need to ensure GPIO at low level, how can I do?
1 回复
1,152 次查看
Carlos_Mendoza
Hi Hubert Wu,
Unfortunately, there is no way to change the GPIO default state, you will need to add an external pull down resistor to place the pin in the desired state.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
