How to disable WWDT while debugging in LPC55
1,513 次查看
jimmyli
      When our customer selected LPC550x MCU to develop, they found the wwdt will reset the mcu while debugging and the SWD doesn't work.
      Also, I find wwdt supporting debug mode, but can't find any way to disable wwdt while debugging.
     Can you help to check it?
     Thanks very much.
----below is a example to disable wwdt while debugging for ST mcu
STM32在DEBUG调试模式下禁止看门狗IWDG WWDG_梓默的博客-CSDN博客_stm32 关闭看门狗
1,504 次查看
xiangjun_rong
I suppose that you can disable WWDT when you develop/debug your application code with the code
SYSCON->AHBCLKCTRLX[0]|=1<<22;
WWDT->MOD&=~(0x01); //disable WWDT by clearing the WDEN bit in MOD reg
Hope it can help you
XiangJunRong
