How to Enter and Display Data from Keyboard in GUI Guider?
3,462件の閲覧回数
nithin3200
I am working on a GUI Guider project where I need to allow users to enter their name and ID number using a keyboard. Could someone guide me on how to achieve this functionality? Specifically, I need to know:
  1. How to capture keyboard input for text fields.
  2. How to display the entered data on the GUI.
  3. Any particular digits or configurations I need to be aware of for handling numeric IDs.
Any example code or references to documentation would be greatly appreciated.
Thanks!
ラベル(2)
3 返答(返信)
3,380件の閲覧回数
aswani
Hello  nithin3200,
As for my knowledge you can follow these steps
  1. Capture Keyboard Input
  2. Display Entered Data
  3. Handle Numeric IDs
Hope this will help you
Developer
3,443件の閲覧回数
EdwinHz
Hi @nithin3200,
This would have to be done with custom code. LVGL documentation has a section for input devices, including keyboards. Please follow section "keypad or keyboard" of the following page for more information on how to manipulate widgets using a keyboard: Input device interface — LVGL documentation.
Then, the label would have to be changed according to the key pressed, with "lv_label_set_text()", more info here Label (lv_label) — LVGL documentation.
You can also look into the example codes provided by LVGL documentation to see how to implement a function like this: Examples — LVGL documentation.
BR,
Edwin.
3,384件の閲覧回数
nithin3200
HI Edwin,
Thank you for the detailed guidance. I'll review the LVGL documentation sections you referenced and try to implement a custom solution using keyboard input to update the label. The example codes will also be helpful.
I appreciate your support. I'll let you know if I have any other questions.
