How much current does the LPC812 consume during code flash?
2,086 次查看
duaneallen
I need to know what the current requirements are when an LPC812 is being flashed. None of the datasheets I can find contain this information.
Thank you,
Duane
1,942 次查看
jeremyzhou
Hi Duane Allen,
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you.
I was wondering if you can clarify what kind of occasion you mean, external programmer program the MCU or inside ISP upgrade the application code?
And Datasheet hasn't provided these information yet, thanks for your understanding.
Ping
1,942 次查看
duaneallen
Hi Ping,
We need to know the current requirements when programming the MCU with an external programmer.
Thank you,
Duane
1,942 次查看
jeremyzhou
Hi Duane Allen,
Thanks for your reply.
To evaluate the consumption when programming the MCU with an external programmer, I consider that you can think of it as MCU runs in Active mode.
Ping
