How do I transfer data via ETHERNET
lpcware
Content originally posted in LPCWare by kevin on Thu Apr 04 10:00:37 MST 2013
I need to make the exchange of information between my development board that is using the LPC1768 and a computer through the "ETHERNET" communication using UDP and SNMP. Since the computer is the CLIENT and the SERVER plate.
Can anyone help me somehow?
Thank you.
lpcware
Content originally posted in LPCWare by aem.nitin on Tue Nov 04 23:32:00 MST 2014
Thank you.
I also need to implement SNMP agent over LPC1768. Can you help me
lpcware
Content originally posted in LPCWare by Pacman on Tue Apr 16 22:13:26 MST 2013
I haven't tried using ethernet on the LPC1768 yet (but I am going to soon, I believe).
If you provide some more information on what you are doing, what hardware you have available and what you want, you might get some (better) answers.
For instance...
<ul>
<li>Which board are you using ?</li>
<li>Which ethernet PHY is on your board.</li>
<li>Which Ethernet library are you using (LWIP ?)</li>
</ul>
Personally, I would probably try and use some HTTP protocol instead of UDP/SNMP, but if your skills are better than mine, I won't tell you to change your opinion. At least for a start, I'd try using HTTP, as it's easier for tests.
If you haven't already had a look at it, try...
<span class="Apple-style-span" style="font-family: 'Myriad Pro', Helvetica, 'Helvetica Neue', Geneva, Arial, Verdana; font-size: 13px; line-height: normal;">git clone http://git.lpcware.com/lwip_lpc.git</span>
or download <span class="Apple-style-span" style="font-family: 'Myriad Pro', Helvetica, 'Helvetica Neue', Geneva, Arial, Verdana; font-size: 13px; line-height: normal;"><a title="lwip_lpc" href="http://sw.lpcware.com/?p=lwip_lpc.git&a=snapshot&h=HEAD&fmt=zip&f=latest">lwip_lpc</a></span>.
