How connect CAN Bus to CANOpen?
lpcware
Content originally posted in LPCWare by h.lotfi on Wed Apr 06 04:03:55 MST 2016
i want connect CAN bus to a PLC with CANOpen!
how can i do it?
can i implement CANOpen layer ? (it's mean i just implement application layer)
if yes, can you get me Reference?
lpcware
bump
lpcware
Content originally posted in LPCWare by robert hulsebos on Sat Apr 09 03:35:22 MST 2016
See http://ixxat.com/contact/-in-category/categories/distributors-partners/
I have no idea from which country you are, but at the bottom of the page there is pull down menu where you can select your country for looking up a local distributor.
lpcware
Content originally posted in LPCWare by h.lotfi on Sat Apr 09 02:57:05 MST 2016
how can i get CANOpen stack from IXXAT?
lpcware
Content originally posted in LPCWare by robert hulsebos on Wed Apr 06 06:04:35 MST 2016
We have a LPC1769 based product that runs(commercial) CANopen stack from IXXAT ( see http://ixxat.com/products/products-industrial/protocol-software-and-apis/protocol-software/canopen-p... ) They have a ready-to-use solution (source code) for various NXP MCU families, see here http://ixxat.com/products/products-industrial/protocol-software-and-apis/protocol-software/canopen-s...
If you want to develop CANopen stack yourself, I recommend becoming member of CiA ( http://www.can-cia.org/ ) first, to get access to CANopen standard documentation and may be for getting CANopen vendor ID. ( see http://www.can-cia.org/services/canopen-vendor-id for details )
nitin_kanani
above links are not found.
please suggest me how can i get CANopen stack for my project
i use LPC1833 controller in my project
