How Do I Run My Firmware After Flashing? (LPCXpresso845MAX Board)
已解决
跳至解决方案
2,048 次查看
kk7xo
I have firmware debugged and running from the debugger in the MCUXpresso IDE (ver. 11.0).  I can use the IDE flash tool to flash the LPC845 with no errors.  However, if I try to run the firmware without the debugger, it never starts up.  I have tried powering the board with JP1 installed or not installed and it makes no difference.
How do I run my firmware stand-alone from flash without a debugger?
标签 (2)
1 解答
1,967 次查看
converse
Senior Contributor V
Take a look at the suggestions in this thread:
https://community.nxp.com/thread/478633
在原帖中查看解决方案
2 回复数
1,967 次查看
kk7xo
Thank you.  Got it working.  I just needed to compile it in release mode and change the library from semihosting to nohost.
1,968 次查看
converse
