How Do I Run My Firmware After Flashing? (LPCXpresso845MAX Board)
kk7xo
I have firmware debugged and running from the debugger in the MCUXpresso IDE (ver. 11.0).  I can use the IDE flash tool to flash the LPC845 with no errors.  However, if I try to run the firmware without the debugger, it never starts up.  I have tried powering the board with JP1 installed or not installed and it makes no difference.
How do I run my firmware stand-alone from flash without a debugger?
Labels (2)
converse
Senior Contributor V
Take a look at the suggestions in this thread:
https://community.nxp.com/thread/478633
kk7xo
Thank you.  Got it working.  I just needed to compile it in release mode and change the library from semihosting to nohost.
converse
