Help Needed: Flashmagic and Web Filtering Software Compatibility Issue
1,588 次查看
judywatson
Hi everyone,
I hope you're all doing well. I'm a complete newbie when it comes to technology, and I'm currently facing a puzzling problem with Flashmagic and my web filtering software. I could really use some assistance from the more experienced members of this community.
So, here's what's happening: I recently started using Flashmagic to program microcontrollers for a project, and I installed web filtering software on my computer for added security. However, it seems like the two are not getting along very well.
When I try to use Flashmagic, I keep getting blocked from accessing certain features, and I suspect it might be due to the web filtering software. I don't know how to check if the web filtering software is causing the issue or if there's something else I need to do.
Can someone please explain to me in simple terms how to ensure that Flashmagic and the web filtering software can work together without any conflicts? I don't want to compromise my project's progress, and I also want to make sure my computer is secure.
Here are some specific questions I have:
How do I check if the web filtering software is causing the problem with Flashmagic?
Are there any specific settings I should adjust in the web filtering software to allow Flashmagic to function properly?
Could there be any other reasons why Flashmagic is not working as expected?
I apologize if these questions sound too basic, but I'm still learning, and your patience would mean a lot to me.
If any of you have experience with Flashmagic and web filtering software, I would greatly appreciate your help in guiding me through this. Please remember to use simple language, so I can follow along easily.
Thank you all so much for your support and understanding. I'm excited to grow my knowledge in technology with your help!
1,576 次查看
ZhangJennie
Hi judywatson
Both Flashmagic and my web filtering software are not NXP's.
We suggest you contacting the two products owner for the question.
Have a nice day,
Jun Zhang
