HOW TO INTERFACE EXTERNAL FLASH MEMORY WITH SPI0 IN LPC2148
4,418 次查看
Hari123pass123
4,388 次查看
ZhangJennie
Hi Hari123pass123
Please note LPC2148 is not in longevity program since Jun 2021. We no longer recommend it for new design. Therefor the material and support for this device is very limited.
There is AN10406 Accessing SD/MMC card using SPI on LPC2000
https://www.nxp.com.cn/docs/en/application-note/AN10406.pdf
and on my disk I found a TN on LPC2xxx SPI master code example. I attach it.
Besides we don't have other material on it.
Please note. If you start new design, we don't suggest LPC2xxx. Please consider LPC or imxRT.
Have a nice day,
Jun Zhang
4,381 次查看
Hari123pass123
thank you for your kind informative sir.
4,389 次查看
ZhangJennie
Hi Hari123pass123
Have a nice day,
Jun Zhang
4,380 次查看
Hari123pass123
Thanks for your replay sir very usefull for your notes
