Get current pin voltage?
1,002 次查看
lpcware
Content originally posted in LPCWare by arturn on Mon May 20 04:38:01 MST 2013
Hi!
I'm reading values from a ADC controller using below formula :
<code>adv_value = adv_value / MAX_VALUE * Voltage</code>
I'm using 5v voltage I would like to use exactly voltage value to improve my read,  not an 5 constant aproximation.
How I can get exactly voltatge in board ?
Thnks!
995 次查看
lpcware
Content originally posted in LPCWare by mc on Tue May 21 20:31:38 MST 2013
Hi arturn,
Could you please explain your question in detail? Are you using evaluation board?
What is the maximum voltage you want to measure using ADC?
NXP Support
