Flashing MIcro SD Card with my App
1,120件の閲覧回数
amenglim
I am trying to flash my program onto my Micro SD Card for board LPC1788 so that on startup, my app is the only thing that appears on the screen. Is there a straightforward way to do this? What would I need to do? I am using CrossWorks IDE for reference.
1,093件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, about your questions could you elaborate further? if you are using an LCD you need to write you application to show something on the LCD, maybe you could use an example to do that. But if you are using an OLED LCD the example that could help you will be the I2C, or SPI depends on your LCD.
If I do not understand your case, please let me know. I will continue the support on this thread because the internal case is replayed.
Pavel
