Fixed point calculation
1,548 次查看
ranjithshanbhag
Is it possible to calculate Fixed point method in LPC824?
Since Floating point calculation requires more time to execute.
1,433 次查看
jeffreycasey
there are primitive operations for add, subtract, multiply.  for division where the divisor is known at coding time, you can find a suitable X and Y where you can multiply by X and shift-right Y bits for division to needed accuracy.  for division where the divisor is only known in realtime, you need a longer routine for division.  there are some good example routines in "ARM System Developer's Guide" by Sloss et al.
