Failed to connect to CPU
4,369 次查看
thanaponjirapan
I am using LPC1817 and IAR Embedded Workbench 7.70.2.
and found this log when run download and debug via i-jet/JTAGjet.
Tue May 15, 2018 09:27:10: IAR Embedded Workbench 7.70.2 (armproc.dll)
Tue May 15, 2018 09:27:10: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\LPC18xx_LPC43xx.dmac
Tue May 15, 2018 09:27:10: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\NXP\FlashNXPLPC18xx.mac
Tue May 15, 2018 09:27:11: Loading the I-jet/JTAGjet driver
Tue May 15, 2018 09:27:11: Probe: Probe SW module ver 1.56
Tue May 15, 2018 09:27:11: Probe: Option: trace(Auto,size_limit=100%)
Tue May 15, 2018 09:27:11: Probe: I-jet-Trace SW module ver 1.61
Tue May 15, 2018 09:27:11: Probe: Found I-jet, SN=82573
Tue May 15, 2018 09:27:11: Probe: Opened connection to I-jet:82573
Tue May 15, 2018 09:27:11: Probe: USB connection verified (11712 packets/sec)
Tue May 15, 2018 09:27:11: Probe: I-jet, FW ver 4.2, HW Ver:A
Tue May 15, 2018 09:27:11: Probe: IJET-ARM20 adapter detected
Tue May 15, 2018 09:27:11: Probe: Versions: JTAG=1.76 SWO=1.36 A2D=1.70 Stream=1.47 SigCom=2.41
Tue May 15, 2018 09:27:11: EARM v.4.4
Tue May 15, 2018 09:27:11: Emulation layer version 4.4
Tue May 15, 2018 09:27:11: JTAG clock detected: 12MHz
Tue May 15, 2018 09:27:11: Chain detected: 1 device, total IR length 4.
Tue May 15, 2018 09:27:11: BoardCfg=!Cortex
Tue May 15, 2018 09:27:11: Notification to core-connect hookup.
Tue May 15, 2018 09:27:11: CoreSight error: Debug interface power and clock request signal has not been acknowledged:
Tue May 15, 2018 09:27:11: o CDBGPWRUPACK signal expected in response to assertion of debug power request CDBGPWRUPREQ.
Tue May 15, 2018 09:27:11: o DAP DP STAT register is 0xd0000000.
Tue May 15, 2018 09:27:11: o Debugging is not possible.
Tue May 15, 2018 09:27:11: CPU status FAILED
Tue May 15, 2018 09:27:12: CoreSight error: Debug interface power and clock request signal has not been acknowledged:
Tue May 15, 2018 09:27:12: o CDBGPWRUPACK signal expected in response to assertion of debug power request CDBGPWRUPREQ.
Tue May 15, 2018 09:27:12: o DAP DP STAT register is 0xd0000000.
Tue May 15, 2018 09:27:12: o Debugging is not possible.
Tue May 15, 2018 09:27:13: CoreSight error: Debug interface power and clock request signal has not been acknowledged:
Tue May 15, 2018 09:27:13: o CDBGPWRUPACK signal expected in response to assertion of debug power request CDBGPWRUPREQ.
Tue May 15, 2018 09:27:13: o DAP DP STAT register is 0xd0000000.
Tue May 15, 2018 09:27:13: o Debugging is not possible.
Tue May 15, 2018 09:27:14: CoreSight error: Debug interface power and clock request signal has not been acknowledged:
Tue May 15, 2018 09:27:14: o CDBGPWRUPACK signal expected in response to assertion of debug power request CDBGPWRUPREQ.
Tue May 15, 2018 09:27:14: o DAP DP STAT register is 0xd0000000.
Tue May 15, 2018 09:27:14: o Debugging is not possible.
Tue May 15, 2018 09:27:14: LowLevelReset(hardware, delay 200)
Tue May 15, 2018 09:27:15: CoreSight error: Debug interface power and clock request signal has not been acknowledged:
Tue May 15, 2018 09:27:15: o CDBGPWRUPACK signal expected in response to assertion of debug power request CDBGPWRUPREQ.
Tue May 15, 2018 09:27:15: o DAP DP STAT register is 0xd0000000.
Tue May 15, 2018 09:27:15: o Debugging is not possible.
Tue May 15, 2018 09:27:17: Fatal error: Failed to connect to CPU Session aborted!
Tue May 15, 2018 09:27:17: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\NXP\FlashNXPLPC18xx.mac
Tue May 15, 2018 09:27:17: IAR Embedded Workbench 7.70.2 (armproc.dll)
Tue May 15, 2018 09:27:18: Loading the I-jet/JTAGjet driver
How to solve "Fatal error: Failed to connect to CPU Session aborted!"??
Thanapon
标签 (3)
标记 (4)
3,367 次查看
victorjimenez
Hello Thanapon,
It seems that you need to recover debug access to the MCU. Please refer to the following community post:
Regaining debug access to target MCU
Hope it helps!
Victor.
