FXOS8700 Sensor Initialization Failed
6,623 次查看
khinhtethtetaung25
I am using application software pack : ML-Based System State Monitor for on LPCXpresso55S69 and FRDM-STBC-AGM01 sensor tool box for FXOS8700 accelerometer. I can successfully debug and terminate the session without any error. However, when I tried to run it on Tera Term (serial console) it showed " FXOS8700 Sensor Initialization Failed" as shown in the photo. Could you please suggest me how to fix this? I am certain all the jumper pins are correctly connected.
Jacquelyn
#FRDM-STBC-AGM01
6,608 次查看
TomasVaverka
Hi Jacquelyn,
One of the reasons of this problem could be the jumper setting on the FRDM-STBC-AGM01, I would recommend to double check it.
Also make sure that the FRDM-STBC-AGM01 board is properly connected to the LPC board.
Did you follow the instructions in the readme.txt and are you able to run any other SDK examples?
Tomas
6,594 次查看
khinhtethtetaung25
Hi Tomas,
Thank you for the reply. I tried to run other SDK and gets the error "ISSDK FXOS8700 sensor driver example demonstration with fifo mode. Sensor Initialization Failed" as shown in the attached image. I have double checked the jumper and all are properly connected. Could suggest me how can I fix it?
Jacquelyn
