External Code Memory
1,297 次查看
Content originally posted in LPCWare by hamidrm on Thu Sep 25 02:19:13 MST 2014
I'm using 1788,J-LINK and KEIL. At my code there are many images data (more than 512KB). Can i use from an external NOR flash memory(like s29gl*) and put images data into the it by programming 1788? I know that the KEIL supports s29gl064 programming , but  can j-link programs s29gl that connected to the 1788?? How can i do it???
[IMG]http://i59.tinypic.com/sgstqa.png[/IMG]
1,272 次查看
Content originally posted in LPCWare by mtgtech on Fri Feb 13 11:51:07 MST 2015
Hi, you found out how to do this? I also like to know how to do.
