Experiencing audio clarity issues while using the WM8904 audio codec
Tharun123
Hello everyone,
I am currently using the WM8904 audio codec in my project. The audio is stored in external flash memory, and I am reading it in chunks of 1024 bytes at a time. The audio format is 16-bit WAV with an 8000 Hz sample rate.
For playback, we are using a mono speaker. I have attached the schematic of our codec for reference.
Issue: The audio output is not clear. I have verified the data being read from the flash, and it matches the stored data.
I would like to know:
  1. What audio formats (sample rate, bit width, clock configuration, etc.) are supported by the WM8904 codec?
  2. How can I ensure proper reading and playback of audio from the flash memory?
Thank you.
Tags (3)
Pavel_Hernandez
Hello, I recommend review the examples on the SDK, there are some different types of application, maybe that could help you.
The 8khz is too low on quality, I recommend review the rate of the example.
Pavel
