Example working project for TFT with LPC832/834
aaronm
This is not a question: I'm just contributing a working project that demonstrates an ST7735 TFT (1.4" in my case) driven by an LPC834, though I suspect an LPC832 might also drive it, if you optimize for space so the binary will fit in flash.
It uses the TFT code base developed by Michal Kozakiewicz, github.com/michal037, found here: https://github.com/michal037/driver-ST7735S
It uses LPC834 SDK 2.16.00 (2024-07-12), which seems to work a little better than 25_06_00, but I may have caused my own problems, there.  2.16.00 at least allows you to use the Peripherals tool to configure ADC, and SPI.
Uncompress the zip file, import the contents into a new project, and off you go.  Hope this helps someone.
Hi @aaronm
Thanks for your sharing.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2332201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20working%20project%20for%20TFT%20with%20LPC832%2F834%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EThis%20is%20not%20a%20question%3C%2FSTRONG%3E%3A%20I'm%20just%20contributing%20a%20working%20project%20that%20demonstrates%20an%20ST7735%20TFT%20(1.4%22%20in%20my%20case)%20driven%20by%20an%20LPC834%2C%20though%20I%20suspect%20an%20LPC832%20might%20also%20drive%20it%2C%20if%20you%20optimize%20for%20space%20so%20the%20binary%20will%20fit%20in%20flash.%3C%2FP%3E%3CP%3EIt%20uses%20the%20TFT%20code%20base%20developed%20by%26nbsp%3BMichal%20Kozakiewicz%2C%20github.com%2Fmichal037%2C%20found%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmichal037%2Fdriver-ST7735S%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fmichal037%2Fdriver-ST7735S%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIt%20uses%20LPC834%20SDK%202.16.00%20(2024-07-12)%2C%20which%20seems%20to%20work%20a%20little%20better%20than%2025_06_00%2C%20but%20I%20may%20have%20caused%20my%20own%20problems%2C%20there.%20%26nbsp%3B2.16.00%20at%20least%20allows%20you%20to%20use%20the%20Peripherals%20tool%20to%20configure%20ADC%2C%20and%20SPI.%3C%2FP%3E%3CP%3EUncompress%20the%20zip%20file%2C%20import%20the%20contents%20into%20a%20new%20project%2C%20and%20off%20you%20go.%20%26nbsp%3BHope%20this%20helps%20someone.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2332201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC800%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Example%20working%20project%20for%20TFT%20with%20LPC832%2F834%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F184079%22%20target%3D%22_blank%22%3E%40aaronm%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20your%20sharing.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E
