Ethernet code work EMAC  initialize  but only U pass 58 times at receiver side LPCXPRESO IDE
VijayaJangam1
Ethernet code work EMAC  initialize  but only U pass 58 times at receiver side not pass my string Please check my code and give me corrections in my code buffer value how  can changes the output UUU how can change give me  solution on this problem (LPC2478 use)                                thank you...
Hello @VijayaJangam1
It seems this question is the same as the one posted at this link. My colleague will reply to you in that thread. No need create so many tickets.
Thank you.
