Ethernet + UART
Ethernet + UART
2,998件の閲覧回数
Content originally posted in LPCWare by wafa on Thu Nov 01 02:01:32 MST 2012
I'm working with an LPC1788 microcontroller(LPC1788 Developer’s Kit - Embedded Artists), i want to send a String to the board via Ethernet port and transfer it to another device via RS232 port. The Ethernet connection between PC and my board works fine but i receive nothing from RS232 port. I don't know where could be the mistake. Here's my code, please help.
Original Attachment has been moved to: ethproj.rar
6 返答(返信)
2,842件の閲覧回数
Content originally posted in LPCWare by zuohaoran943 on Tue Nov 13 01:26:10 MST 2012
Thank you so much for your kindly answer,it helped me a lot,i will attempt to use the HyperTerminal which i didn't know before has such an important function until you had told me. And as for your problem,i can't offer you exactly the effective help right now,as I'm still a recruit in this field.But i have some code examples which is for LPC1768.I don't know whether it could help you, but it's the most i can do.
2,842件の閲覧回数
Content originally posted in LPCWare by wafa on Fri Nov 02 02:23:54 MST 2012
But you can always use the HyperTerminal with the right settings to communicate with the board via Ethernet.
2,842件の閲覧回数
Content originally posted in LPCWare by wafa on Fri Nov 02 02:23:42 MST 2012
2,842件の閲覧回数
Content originally posted in LPCWare by wafa on Fri Nov 02 02:21:01 MST 2012
I developped a desktop application with C# using System.Net library. Any help please !
2,842件の閲覧回数
Content originally posted in LPCWare by zuohaoran943 on Thu Nov 01 09:19:45 MST 2012
Could you please tell me how you sent a string to the board via ethernet port From your PC?Is there any tool for such purpose?
2,842件の閲覧回数
Content originally posted in LPCWare by wafa on Thu Nov 01 02:28:24 MST 2012
Hi all,
Can you help me with some hints or code sample for developing a Ethernet to RS232 converter.The code i have is not working!!
Many thanks!
