Ethernet Code For LPC2478 controller using LPC24xx.h file on LPCXpresso IDE
VijayaJangam1
Ethernet Code For LPC2478 controller using LPC24xx.h file on LPCXpresso IDE  work code Used PHY chip for Ethernet communication and use SRAM it gets problem for Ethernet communication in IDE give me solution.  my all files  are attached here please check and give me  corrections and why this sys_calls.c file is used
Harry_Zhang
