Error1 in build proces
1,067 次查看
lpcware
Content originally posted in LPCWare by sonca on Fri Jan 31 06:54:23 MST 2014
Hi all,
Please help resolve problem. I'm making my first project on LPCXpresso and have an error:
collect2: ld returned 1 exit status
make: *** [Temp_sensor.axf] Error 1
1,059 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Fri Jan 31 07:09:20 MST 2014
Look in the Build console to see what the actual error is:
http://www.lpcware.com/content/faq/lpcxpresso/build-console
If it is not obvious what the cause of the problem is, then search this site (top right of this screen)  for the error. Almost certainly somebody else will have had the same problem.
