Error code 0x00060009 in I2C callback
1,079 次查看
Content originally posted in LPCWare by remcopoelstra on Fri Jul 04 00:05:05 MST 2014
Whenever I set a breakpoint on the I2C interrupt, the callback will report an error of 0x00060009. Without a breakpoint I get error 0 (success). This error code is not mentioned in the manual. What does it mean?
Remco Poelstra
1,058 次查看
Content originally posted in LPCWare by remcopoelstra on Fri Jul 04 02:15:24 MST 2014
Ah, I see that the LPCOpen enum does define the code as timeout error. That seems quite logical.
Maybe the manual needs a little update.
Remco
