Error Li005 IAR ARM
Error Li005 IAR ARM
2,249 次查看
henriaghaei
I am getting the Error Li005 for ARM Cortex M3. I looked at different forums and communities to find a solution to my issue. So, some people suggested that I need to define the "undefined" variables in my C. Some other believe that the settings for the optimization should be modified.
I have done all above things but still no success to resolve the issue. I use the latest version of IAR which is 7.7. According to what I have provided below, what would you kindly suggest me to go ahead and do to resolve the issue?
Thank you in advance.
Building configuration: CINI - Release
Updating build tree...
IPcomm.c
Linking
Error[Li005]: no definition for "htons" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_process" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_arp_out" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_arp_arpin" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_arp_timer" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_udp_conn" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_udp_conns" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_conn" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_conns" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_len" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_buf" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_listen" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\WebInterface.o]
Error[Li005]: no definition for "timer_set" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_arp_init" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_init" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_appdata" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_ethaddr" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_netmask" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_draddr" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error[Li005]: no definition for "uip_hostaddr" [referenced from C:\Users\carma\Desktop\CINIFolder\CINI Production Testing\2nd\CINI Hardware Test\CINI\Release\Obj\IPcomm.o]
Error while running Linker
Total number of errors: 20
Total number of warnings: 0
标记 (3)
1,596 次查看
avt
Looks like you are failing to link with the library that resolves (contains) all of those missing functions. Some sort of network (uip) library?
