Enquiry on Programming LPC5536 MCU in ISP mode using Flash Magic tool
1,674件の閲覧回数
Cheok98
I have accidentally disabled the Debug SWDCLK pin in my firmware and I was unable to reprogram the MCU using MCU link now. I have tried to program the MCU using Flash Magic tool, but it was not working and showing Failed to autobaud error. I also tried to program the MCU using JP3 UART pin and the result is the same (not sure this way is correct or not).
1,665件の閲覧回数
frank_m
Senior Contributor III
If you have disabled your JTAG/SWD interface, you would need to start it into ISP mode (System Mode), to go into the ROM bootloader and prevent your application from taking control.
I don't know your board/MCU, usually you need to set a specific jumper. Just read the board user manual. Or the MCU user manual, if it is a custom board.
1,666件の閲覧回数
frank_m
