Encryption example
Encryption example
Content originally posted in LPCWare by Giuseppe on Wed May 15 05:13:38 MST 2013
LPCWare gives an example for AES encryption. It says it is developed and tested with MDK-ARM Professional. Does anybody tried to use it with LPCXpresso toolchain?
Can it be included as a library or do you need to compile it again? Is it easy to compile it?
Thank you,
Giuseppe Albano
