Ee(83). Hardware Transfer Error.
1,578件の閲覧回数
yasushiaoyama
I  use LPCXpresso V8.2.2_650.  I sometimes encounter error in programming flash:  '05: File xxx.axf load failure: Ee(83). Hardware Transfer Error.  This become success after several time retry.  Somebody knows the reason of the error?
I use LPC4330-Xplorer board.
Y. Aoyama
タグ(2)
1,523件の閲覧回数
jeremyzhou
Hi Yasushi Aoyama ,
for the opportunity to serve you.
Whether you can introduce which debug tool you used, in addition, do you find the way of replicating the phenomenon?
Ping
