ECDA signature verification with CASPER
202件の閲覧回数
s_hdl
スポイラ
I managed to build mbedTLS on my own, in order to verify a signature with ECDSA (MBEDTLS_ECP_DP_SECP256R1).
With no alt implementation (all computation done by the CPU), the signature verification takes up to 4 seconds to compute on the LPC55S06.
I'm trying now to link mbedTLS ecdsa_verify() function with CASPER fsl driver. But it's not clear to me as the ECDSA verification doens't seem to be a single operation.
How to link the basic primitive of CAPSER (SECP256R1_Mul & SECP256R1_MulAdd) with the mbedTLS function ECDSA_verify() ?
Thank you in advance for your replie.
177件の閲覧回数
Harry_Zhang
Hi @s_hdl
ECDSA verification consists of several arithmetic and elliptic-curve operations, so it does not map to a single CASPER primitive.
In the MCUXpresso SDK, the integration is already implemented in the CASPER PSA Crypto port. The casper_mbedtls_ecdsa_verify() function performs the standard ECDSA verification flow, including the calculation of u1 and u2. It then calls:
casper_mbedtls_ecp_muladd(grp, &R, u1, &grp->G, u2, Q);
to calculate:
R = u1 × G + u2 × Q
The ECP adaptation layer converts the mbedTLS MPI values and elliptic-curve points into the format required by CASPER and maps this operation to CASPER_ECC_SECP256R1_MulAdd().
Similarly, casper_mbedtls_ecp_mul() maps a single scalar multiplication to CASPER_ECC_SECP256R1_Mul().
Therefore, rather than modifying mbedtls_ecdsa_verify() directly, we recommend reusing the complete CASPER integration provided by the SDK under:
component/psa_crypto_driver/casper_driver
In particular, please refer to:
mcux_psa_casper_ecdsa_port.c
mcux_psa_casper_ecp_port.c
Since you built mbedTLS separately, please also make sure that your mbedTLS version is compatible with the MCUXpresso SDK CASPER port.
You can refer to the lpcxpresso55s06_psa_crypto_examples.
Harry
4 返答(返信)
173件の閲覧回数
peter89jean
You generally don’t need to replace mbedtls_ecdsa_verify() itself; the CASPER acceleration should be integrated at the elliptic-curve/multiplication layer that mbedTLS uses internally. ECDSA verification requires computing scalar multiplications and their sum, so SECP256R1_Mul() can handle the individual scalar-point multiplication while SECP256R1_MulAdd() can accelerate the combined operation. The exact integration depends on your mbedTLS version and NXP CASPER driver API, but the usual approach is to provide an mbedTLS alternative/optimized implementation for the P-256 scalar-multiplication primitives rather than calling CASPER directly from ecdsa_verify().
165件の閲覧回数
s_hdl
Hello peter89jean,
Thank you for your reply. The approach you mention is what I had in mind but there doesn't seem to be simple and straightforward SECP256R1_MULADD_ALT or SECP256R1_MUL_ALT defines in the mbedTLS config file. Maybe I should ask this question to a more mbdedTLS dedicated forum.
Thanks again.
Regards.
178件の閲覧回数
Harry_Zhang
Hi @s_hdl
to calculate:
R = u1 × G + u2 × Q
Harry
156件の閲覧回数
s_hdl
Hello Harry,
Your answer helped me a lot, thank you. Everything works fine using the CASPER implementation now.
Regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2411077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECASPER%E3%81%AB%E3%82%88%E3%82%8BECDA%E7%BD%B2%E5%90%8D%E6%A4%9C%E8%A8%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%82%BF%E3%83%90%E3%83%AC%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%97%E3%81%A6%E8%AA%AD%E3%82%80%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%26nbsp%3B%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20ECDSA%EF%BC%88MBEDTLS_ECP_DP_SECP256R1%EF%BC%89%E3%81%A7%E7%BD%B2%E5%90%8D%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81mbedTLS%E3%82%92%E7%8B%AC%E8%87%AA%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E4%BB%A3%E6%9B%BF%E5%AE%9F%E8%A3%85%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%EF%BC%88%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%A8%88%E7%AE%97%E3%81%8CCPU%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%89%E3%80%81LPC55S06%E3%81%A7%E3%81%AF%E7%BD%B2%E5%90%8D%E6%A4%9C%E8%A8%BC%E3%81%AE%E8%A8%88%E7%AE%97%E3%81%AB%E6%9C%80%E5%A4%A74%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%8A%E3%80%81mbedTLS%20ecdsa_verify()%E9%96%A2%E6%95%B0%E3%82%92CASPER%20FSL%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81ECDSA%E6%A4%9C%E8%A8%BC%E3%81%AF%E5%8D%98%E4%B8%80%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%A7%81%E3%81%AB%E3%81%AF%E3%82%88%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3ECAPSER%E3%81%AE%E5%9F%BA%E6%9C%AC%E3%83%97%E3%83%AA%E3%83%9F%E3%83%86%E3%82%A3%E3%83%96%EF%BC%88SECP256R1_Mul%E3%81%A8SECP256R1_MulAdd%EF%BC%89%E3%82%92mbedTLS%E9%96%A2%E6%95%B0ECDSA_verify()%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2411077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81peter89jean%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E6%96%B9%E6%B3%95%E3%81%AF%E7%A7%81%E3%81%8C%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81mbedTLS%20%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E5%88%86%E3%81%8B%E3%82%8A%E3%82%84%E3%81%99%E3%81%84%20SECP256R1_MULADD%20%3CSTRONG%3E_ALT%3C%2FSTRONG%3E%E3%81%BE%E3%81%9F%E3%81%AF%20SECP256R1_MUL%20%3CSTRONG%3E_ALT%3C%2FSTRONG%3E%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%89%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82mbdedTLS%E3%81%AB%E7%89%B9%E5%8C%96%E3%81%97%E3%81%9F%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%97%E3%81%9F%E6%96%B9%E3%81%8C%E8%89%AF%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E5%BA%A6%E3%80%81%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%80%9A%E5%B8%B8%E3%80%81mbedtls_ecdsa_verify()%20%E8%87%AA%E4%BD%93%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82CASPER%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81mbedTLS%20%E3%81%8C%E5%86%85%E9%83%A8%E7%9A%84%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%A5%95%E5%86%86%E6%9B%B2%E7%B7%9A%2F%E4%B9%97%E7%AE%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82ECDSA%E6%A4%9C%E8%A8%BC%E3%81%A7%E3%81%AF%E3%82%B9%E3%82%AB%E3%83%A9%E3%83%BC%E4%B9%97%E7%AE%97%E3%81%A8%E3%81%9D%E3%81%AE%E5%92%8C%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81SECP256R1_Mul()%E3%81%AF%E5%80%8B%E3%80%85%E3%81%AE%E3%82%B9%E3%82%AB%E3%83%A9%E3%83%BC%E7%82%B9%E3%81%AE%E4%B9%97%E7%AE%97%E3%82%92%E5%87%A6%E7%90%86%E3%81%97%E3%80%81SECP256R1_MulAdd()%E3%81%AF%E7%B5%90%E5%90%88%E6%93%8D%E4%BD%9C%E3%82%92%E5%8A%A0%E9%80%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E7%A2%BA%E3%81%AA%E7%B5%B1%E5%90%88%E3%81%AFmbedTLS%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8NXP%20CASPAR%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCAPI%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E3%80%81ecdsa_verify()%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5CASPER%E3%82%92%E5%91%BC%E3%81%B6%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81P-256%E3%81%AE%E3%82%B9%E3%82%AB%E3%83%A9%E3%83%BC%E4%B9%97%E7%AE%97%E3%83%97%E3%83%AA%E3%83%9F%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6mbedTLS%E3%81%AE%E4%BB%A3%E6%9B%BF%2F%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E5%AE%9F%E8%A3%85%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266219%22%20target%3D%22_blank%22%3E%40s_hdl%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EECDSA%E6%A4%9C%E8%A8%BC%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E7%AE%97%E8%A1%93%E3%81%8A%E3%82%88%E3%81%B3%E6%A5%95%E5%86%86%E6%9B%B2%E7%B7%9A%E6%BC%94%E7%AE%97%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AECASPAR%E3%83%97%E3%83%AA%E3%83%9F%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EMCUXpresso%20SDK%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E7%B5%B1%E5%90%88%E3%81%AF%E3%81%99%E3%81%A7%E3%81%ABCASPER%20PSA%20Crypto%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82casper_mbedtls_ecdsa_verify()%20%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81u1%20%E3%81%A8%20u2%20%E3%81%AE%E8%A8%88%E7%AE%97%E3%82%92%E5%90%AB%E3%82%80%E3%80%81%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%20ECDSA%20%E6%A4%9C%E8%A8%BC%E3%83%95%E3%83%AD%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ecasper_mbedtls_ecp_muladd(grp%2C%20%26amp%3BR%2C%20u1%2C%20%26amp%3Bgrp-%26gt%3BG%2C%20u2%2C%20Q)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%3E%E8%A8%88%E7%AE%97%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ER%20%3D%20u1%20%C3%97%20G%20%2B%20u2%20%C3%97%20Q%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%3E%0A%3CP%3EECP%E9%81%A9%E5%BF%9C%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AF%E3%80%81mbedTLS%20MPI%E5%80%A4%E3%81%A8%E6%A5%95%E5%86%86%E6%9B%B2%E7%B7%9A%E7%82%B9%E3%82%92%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20CASPER%20%E3%81%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E5%BD%A2%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%81%93%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E6%93%8D%E4%BD%9C%E3%82%92%3C%2FSPAN%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER_ECC_SECP256R1_MulAdd()%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%81%AB%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%20%E5%8D%98%E4%B8%80%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%82%B9%E3%82%AB%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E4%B9%97%E7%AE%97%E3%82%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%81%AB%3C%2FSPAN%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ecasper_mbedtls_ecp_mul()%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER_ECC_SECP256R1_Mul()%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E7%9B%B4%E6%8E%A5%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Embedtls_ecdsa_verify()%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%80%81%20SDK%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E7%B5%B1%E5%90%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E5%AE%8C%E5%85%A8%E3%81%AA%20%E5%86%8D%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E5%88%A9%E7%94%A8%20%E3%82%92%E6%8E%A8%E5%A5%A8%20%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ecomponent%2Fpsa_crypto_driver%2Fcasper_driver%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E7%89%B9%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%80%81%3C%2FSPAN%3E%E4%BB%A5%E4%B8%8B%E3%82%92%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%81%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E5%8F%82%E7%85%A7%3C%2FSPAN%3E%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Emcux_psa_casper_ecdsa_port.c%0Amcux_psa_casper_ecp_port.c%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EmbedTLS%E3%82%92%E5%88%A5%E9%80%94%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81mbedTLS%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8CMCUXpresso%20SDK%20CASPAR%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Elpcxpresso55s06_psa_crypto_examples%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1788493275769.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1788493275769.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1788493275769.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395899i1B18FB8ED74F1966%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1788493275769.png%22%20alt%3D%22Harry_Zhang_0-1788493275769.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1788493275769.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1788493275769.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1788493275769.png%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%20%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%8F%E3%83%AA%E3%83%BC%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AF%E5%A4%A7%E5%A4%89%E5%8F%82%E8%80%83%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CASPER%E3%81%AE%E5%AE%9F%E8%A3%85%E3%82%92%E4%BD%BF%E3%81%86%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8B%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
