Debugging in MCUXpresso IDE
7,019 次查看
DHARSAN
   I'm currently working UART communication of receiving while debugging in the controller with the board, it occurs Hardfault error so that I couldn't debug. Though when working in EVK board debugging works without any issue. And I have attached the screenshot below.
7 回复数
7,005 次查看
_Leo_
Could you please tell us which MCU/part are you using please?
6,979 次查看
DHARSAN
MCUXpresso IDE V 11.8.0_1165 & LPC55S16 microcontroller
6,968 次查看
Hello @DHARSAN
Do you mean the same example works well on EVK board, while there is issue with your own board?
How about debug a simple led or hello world demo on your custom board? Or create a new project based on your chip to test. Pay attention choose correct part number.
Alice
6,961 次查看
DHARSAN
receiving same data in controller when transmitting different data from uart module
6,951 次查看
Hello @DHARSAN
"receiving same data in controller when transmitting different data from uart module"
->> If so, you need check your code.
Alice
6,942 次查看
DHARSAN
But I'm working in the SDK example code  which is modified for receiving only
6,817 次查看
Hello @DHARSAN
1> So recommend you first use SDK demo without any modification.
2> Check whether enable UART clock and pin clock you used.
Alice
