Debugging LPC812 Cortex m0 MCUs
1,414件の閲覧回数
lpcware
Content originally posted in LPCWare by dizgah on Mon Mar 07 02:09:03 MST 2016
Is this possible to debugging applications on this MCU?has any one experiences with this?As Datasheet says it is possible to debugging in SWD mode but with JLINK /Keil & LPCLINK/LPCEXPRESSO we had no success.
Also i used small breakout board & soldered lpc812 pins as described in datasheet for debaugging
Keil shows this error:
[img]http://i.stack.imgur.com/g17hB.gif[/img]
[color=#900]EDIT:[/color]
It works on Ram debugging
2 返答(返信)
1,377件の閲覧回数
lpcware
bump
1,377件の閲覧回数
lpcware
Content originally posted in LPCWare by vtw.433e on Mon Mar 07 02:14:09 MST 2016
Yes, of course you can debug, I use LPCXpresso and LPC-Link2. Have you tried that? What is your board? What errors do you get?
