Debugger for LPC1769 on CLEV6630BM
1,007 次查看
nc-an-tech
I have just placed order for CLEV6630BM to evaluate the NFC frontend IC. I would like to be able to run some of the provided example projects as described in AN11022. This document specifies that an LPC-LINK2 is required for programming the host micro (LPC1769) on this dev board. However, this debugger is no longer available and has been replaced with the MCU-LINK debugger but the LPC1769 is not listed among the supported devices for the MCU-LINK. I am planning to order one of these anyway and hope that I can use it with the LPC1769 as I haven't been able to find any alternative.
What would be the recommended way of programming the LPC1769 on the CLEV6630BM?
989 次查看
xiangjun_rong
Although the MCU-LINK device does not list  to support LPC17xx, it supports LPC17xx with MCUXPresso IDE, you can download/program flash of LPC17xx with MCUXPresso IDE.
Hope it can help you
XiangJun Rong
