DSP Sample code for LPC4367
2,156 次查看
gauravmore
I am new to CMSIS library in LPC Expresso. Is ther any reference code which provides the functionality and understanding of DSP library in order to check the FFT output  by sending the samples recieved?
Please provide the solution or reference code for the same, since cannot find it in the code bundle provided in LPCexpresso.
标签 (2)
1,855 次查看
converse
Senior Contributor V
This may be helpful to you:
CMSIS DSP Library Support
The library can be found in the Examples directory of the MCUXpresso install.
1,855 次查看
jeremyzhou
Hi Gaurav More,
for the opportunity to serve you.
To provide the fastest possible support, I'd highly recommend you refer to LPC43xx CMSIS-Compliant Standard Peripheral Firmware Driver Library whose link is below.
Have a great day.
TIC
