DAC to LPC54616
DAC to LPC54616
1,033 次查看
Nadia
Good morning,
I was wondering if someone could recommend a DAC for use with the LPC54616 microcontroller, which is powered at 3.3V.
The aim is to convert a PWM signal generated by the microcontroller into a triangular signal.
Best regards.
1,014 次查看
ZhangJennie
NXP has 8-bit I2C A/D and D/A converter PCF8591. Operating supply voltage 2.5 V to 6.0 V
https://www.nxp.com/products/interfaces/ic-spi-serial-interface-devices/ic-dacs-and-adcs/8-bit-a-d-a...
For more DAC, I suggest you checking 3rd parties, for example ADI.
Have a nice day,
Jun Zhang
