Crash of emWin library when text is rotated
1,007 次查看
lpcware
Content originally posted in LPCWare by Herrbert on Wed Mar 02 08:01:34 MST 2016
I use GUI_DispStringInRectEx to rotate a text.
Here is a simple snippet:
GUI_RECT rect = {0, 0, 300, 300};
GUI_DispStringInRectEx("Text", &rect,
            (GUI_TA_VCENTER | GUI_TA_HCENTER),
            7, GUI_ROTATE_180);
This code works, when called with GUI_ROTATE_0. When it is called with any other value e.g. GUI_ROTATE_180 then a hardfault occures.
I use the following environment:
LP1788 on custom board
Crossworks 2.3.5
Precompiled emWin 5.30c library from NXP
Has anyone else experienced the same problem?
Thanks!
885 次查看
lpcware
bump
