Control problems for LPC1857 with extern 16-bit SRAM ( Urgent )
1,297件の閲覧回数
Content originally posted in LPCWare by ken-wt on Mon Jun 29 19:45:22 MST 2015
I use the Cypress SRAM "CY62167DV30" 1M x16 bit on LPC1857 paltform.
On 16-bit mode is incorrect output , and I try modify hardware to 8-bit mode.
On 8-bit mode is working fine.
I attach the schematic and code.
Would you please tell me how to solve this problem.
Thanks so much.
Original Attachment has been moved to: 16BIT_LPC1857_MEMORY.zip
Original Attachment has been moved to: 8BIT_LPC1857_MEMORY.zip
1,189件の閲覧回数
Content originally posted in LPCWare by ken-wt on Sun Jul 12 18:44:49 MST 2015
Hi bavarian,
Thank you for your comment.
We have to solve the problem.
We try to change the register " STATICWAITOEN0" to zero , then the memory testing is working fine.
Have a nice day.
1,189件の閲覧回数
Content originally posted in LPCWare by bavarian on Fri Jul 10 03:00:51 MST 2015
I don't see major mistake in you configuration, but the buffer needs to be enabled:
LPC_EMC->STATICCONFIG0 |= 1 << 19;
NXP Technical Support Team
