Conection of PLC and LPC804 via Modbus RTU
Mayk_Blanco
Hello everyone!
I'm new to the world of microcontrollers. I'm trying to design a master-slave system with LPC804 (master) and Eaton PLC (slave). The system has to be connected via Modbus RTU, but I have no idea how to make the hardware connection between the microcontroller and the PLC. Do I need some kind of external component? Any suggestions are welcome.
Thanks for your time.
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, the protocol Modbus can be mounted on UART, for long distances you will need a transceiver, that makes the communication of tx and rx to the differential. The way to know what transceiver you need is by reviewing how the PLC supports this protocol.
Pavel
Pavel_Hernandez
Pavel
