If I run this code:
#define CTIMER CTIMER2 /* Timer 2 */
#define CTIMER_MAT_OUT kCTIMER_Match_1 /* Match output 1 */
#define CTIMER_CLK_FREQ CLOCK_GetCTimerClkFreq(2U)
CLOCK_AttachClk(kFRO_HF_to_CTIMER2);
CTIMER_GetDefaultConfig(&ctimer_config);
CTIMER_Init(CTIMER, &ctimer_config);
matchConfig.enableCounterReset = true;
matchConfig.enableCounterStop = false;
matchConfig.matchValue = CTIMER_CLK_FREQ / 2;
matchConfig.outControl = kCTIMER_Output_Toggle;
matchConfig.outPinInitState = true;
matchConfig.enableInterrupt = false;
CTIMER_SetupMatch(CTIMER, CTIMER_MAT_OUT, &matchConfig);
CTIMER_StartTimer(CTIMER);
sprintf(debug_message, "Clock Frequency is %d\n", CTIMER_CLK_FREQ);
USART_WriteBlocking(BENNU_USART, debug_message, (sizeof(debug_message) / sizeof(debug_message[0])) - 1);
I get the correct output "Clock Frequency is 96000000"
But if I change the first define to #define CTIMER CTIMER1 /* Timer 1 */
And change the Clock Attach statement to CLOCK_AttachClk(kFRO_HF_to_CTIMER1);
Then I get the output "Clock Frequency is 0"
And my output doesn't toggle.
Can you please let me know what's going on?
Thanks.
