Can LPC55S0x CANFD support 1Mbps (arbitartion stage) and 8Mbps(data stage)
jimmyli
Contributor V
Hi NXP,
      Can LPC55S0x support 1Mbps in arbitration stage and 8Mbps in data stage ?
      I can't find in LPC55S0x datasheet.
     Thanks very much.
Harry_Zhang
Hi @jimmyli
Yes— the LPC55S0x CAN-FD controller can be configured for 1 Mbit/s arbitration and 8 Mbit/s data , provided the MCAN functional clock is 96 MHz and the external CAN-FD transceiver and physical network support 8 Mbit/s.
The reason this is not listed directly in the datasheet is that the bit rates are derived from the MCAN clock and the NBTP / DBTP timing registers rather than specified as a fixed maximum. The CAN clock can use main_clk with CANCLKDIV = 0 (divide-by-1), and the LPC55S0x maximum clock frequency is 96 MHz.
Harry
Harry_Zhang
Hi @jimmyli
Harry
jimmyli
Contributor V
Hi Harry,
      Got it.
      Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2416632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECan%20LPC55S0x%20CANFD%20support%201Mbps%20(arbitartion%20stage)%20and%208Mbps(data%20stage)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Can%20LPC55S0x%20support%201Mbps%20in%20arbitration%20stage%20and%208Mbps%20in%20data%20stage%20%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20I%20can't%20find%20in%20LPC55S0x%20datasheet.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BThanks%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2416632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Can%20LPC55S0x%20CANFD%20support%201Mbps%20(arbitartion%20stage)%20and%208Mbps(data%20stage)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Harry%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Got%20it.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Thanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Can%20LPC55S0x%20CANFD%20support%201Mbps%20(arbitartion%20stage)%20and%208Mbps(data%20stage)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F69183%22%20target%3D%22_blank%22%3E%40jimmyli%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%E2%80%94%20the%20LPC55S0x%20CAN-FD%20controller%20can%20be%20configured%20for%201%20Mbit%2Fs%20arbitration%20and%208%20Mbit%2Fs%20data%20%2C%20provided%20the%20MCAN%20functional%20clock%20is%2096%20MHz%20and%20the%20external%20CAN-FD%20transceiver%20and%20physical%20network%20support%208%20Mbit%2Fs.%3C%2FP%3E%0A%3CP%3EThe%20reason%20this%20is%20not%20listed%20directly%20in%20the%20datasheet%20is%20that%20the%20bit%20rates%20are%20derived%20from%20the%20MCAN%20clock%20and%20the%20NBTP%20%2F%20DBTP%20timing%20registers%20rather%20than%20specified%20as%20a%20fixed%20maximum.%20The%20CAN%20clock%20can%20use%20main_clk%20with%20CANCLKDIV%20%3D%200%20(divide-by-1)%2C%20and%20the%20LPC55S0x%20maximum%20clock%20frequency%20is%2096%20MHz.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
