Calibration of FRO in LPC546xx
517 次查看
carstengroen
Senior Contributor II
On the LPC546xx devices, we can select between 48MHz and 96MHz FRO (and 12MHz etc).
In the datasheet, it is mentioned that "the FRO is trimmed to +/- 1%" but in the Users Manual it is outlined as if it is only the 96 MHz that is factory trimmed. However, when selecting between the 48 and 96 MHz FRO I see that the FROCTRL trim values changes, so I guess that both FRO's are indeed factory trimmed. Can you confirm this ?
The background is we see deviations of up to -4% on the 48 MHz FRO which we use, but so far, only on devices where the PCB has been potted. I wonder if the mechanical "changes" somehow can influence the FRO calibration (if the 48MHz FRO is calibrated from factory)
Datasheet:
Users Manual:
493 次查看
Harry_Zhang
Hi @carstengroen
"However, when selecting between the 48 and 96 MHz FRO I see that the FROCTRL trim values changes, so I guess that both FRO's are indeed factory trimmed. Can you confirm this ?"
Yes, you are right.
The FRO (12/48/96 MHz) of LPC546xx is factory calibrated (± 1%).
You can refer to these chapters.
"Why you can still measure −4% on some boards?"
Even if the factory has been adjusted by ± 1%,
Environmental factors, especially encapsulation, can still cause significant additional deviations in internal RC/ring oscillators.
Hope this will help you.
Harry
5 回复数
476 次查看
carstengroen
Thanks @Harry_Zhang , so all the FRO oscillators are calibrated from factory. We see some deviation (3 to 4%) on devices (that are potted), we will figure something out with regards to calibration (using the FROCTRL register).
Thanks for your input!
494 次查看
Harry_Zhang
Hi @carstengroen
Yes, you are right.
Harry
412 次查看
carstengroen
@Harry_Zhang , do you have some more information on how the encapsulation can influence the FRO frequency?
Has it to do with mechanical stress on the CPU or something else ?
We see that using potting compound, the FRO will change (go lower in frequency) with about 3 to 4% compared to "non potted" devices.
358 次查看
Harry_Zhang
Hi @carstengroen
It is normal for the FRO frequency of LPC546xx to shift by 3-4% due to encapsulation, and it is not a chip or calibration issue.
main cause:
1. Mechanical stress: Curing shrinkage of sealing material  Delay change of ring oscillator Frequency decrease
2. Changes in thermal environment: After encapsulation, the chip becomes hotter, temperature can decrease by 2-5% with a few degrees of temperature increase
3. Parasitic capacitance and changes in power environment: can also cause small offsets
The impact of encapsulation on internal RC/ring oscillators is a common phenomenon in the industry.
If high precision is required:
I think you can use an external crystal oscillator
or measure and calibrate FRO Trim with software after encapsulation.
Harry
348 次查看
carstengroen
Thanks @Harry_Zhang
Yes, understood. We can easily overcome this in our application by trimming, it seems that it is not (at all) temperature dependent what we see, so thats a good thing
We will do some more testing here.
%3CLINGO-SUB%20id%3D%22lingo-sub-2204946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%A0%A1%E5%87%86%20LPC546xx%20%E4%B8%AD%E7%9A%84%20FRO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%20LPC546xx%20%E8%AE%BE%E5%A4%87%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%9C%A8%2048MHz%20%E5%92%8C%2096MHz%20FRO%EF%BC%88%E4%BB%A5%E5%8F%8A%2012MHz%20%E7%AD%89%EF%BC%89%E4%B9%8B%E9%97%B4%E8%BF%9B%E8%A1%8C%E9%80%89%E6%8B%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E6%8F%90%E5%88%B0%22%EF%BC%8CFRO%20%E7%9A%84%E5%BE%AE%E8%B0%83%E8%8C%83%E5%9B%B4%E4%B8%BA%20%2B%2F-%201%25%22%20%EF%BC%8C%E4%BD%86%E5%9C%A8%E3%80%8A%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E3%80%8B%E4%B8%AD%EF%BC%8C%E4%BC%BC%E4%B9%8E%E5%8F%AA%E6%9C%89%2096%20MHz%20%E5%9C%A8%E5%87%BA%E5%8E%82%E6%97%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%BE%AE%E8%B0%83%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E5%9C%A8%2048%20%E5%92%8C%2096%20MHz%20FRO%20%E4%B9%8B%E9%97%B4%E8%BF%9B%E8%A1%8C%E9%80%89%E6%8B%A9%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%20FROCTRL%20%E7%9A%84%E8%B0%83%E6%95%B4%E5%80%BC%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E7%8C%9C%E4%B8%A4%E4%B8%AA%20FRO%20%E7%A1%AE%E5%AE%9E%E5%9C%A8%E5%87%BA%E5%8E%82%E6%97%B6%E9%83%BD%E7%BB%8F%E8%BF%87%E4%BA%86%E4%BF%AE%E5%89%AA%E3%80%82%E6%82%A8%E8%83%BD%E8%AF%81%E5%AE%9E%E8%BF%99%E4%B8%80%E7%82%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%83%8C%E6%99%AF%E6%98%AF%EF%BC%8C%E5%9C%A8%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%8448%20MHz%20FRO%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9C%8B%E5%88%B0%E7%9A%84%E5%81%8F%E5%B7%AE%E9%AB%98%E8%BE%BE-4%EF%BC%85%EF%BC%8C%E4%BD%86%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E4%BB%85%E5%9C%A8%E5%B7%B2%E5%AE%89%E8%A3%85PCB%E7%9A%84%E8%AE%BE%E5%A4%87%E4%B8%8A%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%22%E7%9A%84%E6%9C%BA%E6%A2%B0%E5%8F%98%E5%8C%96%22%20%E6%98%AF%E5%90%A6%E4%BC%9A%E5%9C%A8%E6%9F%90%E7%A7%8D%E7%A8%8B%E5%BA%A6%E4%B8%8A%E5%BD%B1%E5%93%8D%20FRO%20%E7%9A%84%E6%A0%A1%E5%87%86%EF%BC%88%E5%A6%82%E6%9E%9C%2048MHz%20FRO%20%E5%87%BA%E5%8E%82%E6%97%B6%E5%B7%B2%E6%A0%A1%E5%87%86%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carstengroen_0-1763103316829.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carstengroen_0-1763103316829.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365646i1AD8B0FB2C5AB7FB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22carstengroen_0-1763103316829.jpeg%22%20alt%3D%22carstengroen_0-1763103316829.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carstengroen_1-1763103327194.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carstengroen_1-1763103327194.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365647i0887CD4580AA5C28%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22carstengroen_1-1763103327194.jpeg%22%20alt%3D%22carstengroen_1-1763103327194.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2204946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC546xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calibration%20of%20FRO%20in%20LPC546xx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E6%9B%B4%E5%A4%9A%E5%85%B3%E4%BA%8E%E5%B0%81%E8%A3%85%E5%A6%82%E4%BD%95%E5%BD%B1%E5%93%8D%20FRO%20%E9%A2%91%E7%8E%87%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%90%A6%E4%B8%8E%20CPU%20%E7%9A%84%E6%9C%BA%E6%A2%B0%E5%BA%94%E5%8A%9B%E6%9C%89%E5%85%B3%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9C%8B%E5%88%B0%EF%BC%8C%E4%B8%8E%20%22%20%E9%9D%9E%E7%9B%86%E6%A0%BD%E5%9E%8B%20%22%20%E8%AE%BE%E5%A4%87%E7%9B%B8%E6%AF%94%EF%BC%8C%E4%BD%BF%E7%94%A8%E7%81%8C%E5%B0%81%E5%8C%96%E5%90%88%E7%89%A9%EF%BC%8CFRO%20%E5%B0%86%E5%8F%91%E7%94%9F%E7%BA%A6%203%25%20%E5%88%B0%204%25%20%E7%9A%84%E5%8F%98%E5%8C%96%EF%BC%88%E9%A2%91%E7%8E%87%E9%99%8D%E4%BD%8E%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calibration%20of%20FRO%20in%20LPC546xx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%89%80%E6%9C%89%20FRO%20%E6%8C%AF%E8%8D%A1%E5%99%A8%E9%83%BD%E5%9C%A8%E5%87%BA%E5%8E%82%E6%97%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%A0%A1%E5%87%86%E3%80%82%E6%88%91%E4%BB%AC%E5%9C%A8%E8%AE%BE%E5%A4%87%EF%BC%88%E5%B7%B2%E7%A7%BB%E6%A4%8D%EF%BC%89%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%B8%80%E4%BA%9B%E5%81%8F%E5%B7%AE%EF%BC%883%EF%BC%85%E8%87%B34%EF%BC%85%EF%BC%89%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E6%89%BE%E5%87%BA%E4%B8%80%E4%BA%9B%E6%9C%89%E5%85%B3%E6%A0%A1%E5%87%86%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%88%E4%BD%BF%E7%94%A8FROCTRL%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E6%84%8F%E8%A7%81%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calibration%20of%20FRO%20in%20LPC546xx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105884%22%20target%3D%22_blank%22%3E%40carstengroen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%22%20%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%2048%20%E5%92%8C%2096%20MHz%20FRO%20%E4%B9%8B%E9%97%B4%E8%BF%9B%E8%A1%8C%E9%80%89%E6%8B%A9%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%20FROCTRL%20%E7%9A%84%E8%B0%83%E6%95%B4%E5%80%BC%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E7%8C%9C%E4%B8%A4%E4%B8%AA%20FRO%20%E7%A1%AE%E5%AE%9E%E5%9C%A8%E5%87%BA%E5%8E%82%E6%97%B6%E9%83%BD%E7%BB%8F%E8%BF%87%E4%BA%86%E4%BF%AE%E5%89%AA%E3%80%82%E4%BD%A0%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%E3%80%82%3C%2FP%3E%0A%3CP%3ELPC546xx%20%E7%9A%84%20FRO%EF%BC%8812%2F48%2F96%20MHz%EF%BC%89%E5%B7%B2%E5%9C%A8%E5%87%BA%E5%8E%82%E6%97%B6%E6%A0%A1%E5%87%86%EF%BC%88%C2%B1%201%25%20%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E8%BF%99%E4%BA%9B%E7%AB%A0%E8%8A%82%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1763112863692.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1763112863692.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365685iA54C063929B4D611%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1763112863692.png%22%20alt%3D%22Harry_Zhang_1-1763112863692.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1763112782136.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1763112782136.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F365684i5C11C3059AA20C7B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1763112782136.png%22%20alt%3D%22Harry_Zhang_0-1763112782136.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%22%20%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E6%9F%90%E4%BA%9B%E6%9D%BF%E4%B8%8A%E4%BD%A0%E8%BF%98%E8%83%BD%E6%B5%8B%E9%87%8F%20%E2%88%92%204%25%EF%BC%9F%22%3C%2FP%3E%0A%3CP%3E%E5%8D%B3%E4%BD%BF%E5%87%BA%E5%8E%82%E6%97%B6%E5%B7%B2%E8%B0%83%E6%95%B4%E4%BA%86%20%C2%B1%201%25%2C%3CBR%20%2F%3E%E7%8E%AF%E5%A2%83%E5%9B%A0%E7%B4%A0%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%B0%81%E8%A3%85%EF%BC%8C%E4%BB%8D%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%86%85%E9%83%A8%20RC%2F%E7%8E%AF%E5%BD%A2%E6%8C%AF%E8%8D%A1%E5%99%A8%E5%87%BA%E7%8E%B0%E6%98%8E%E6%98%BE%E7%9A%84%E9%A2%9D%E5%A4%96%E5%81%8F%E5%B7%AE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
