CORTEX M4 instruction set
SunilKalivarapu
is there any possibility of using ROL instruction as there is no opcode provided for that instruction in technical reference manual.
xiangjun_rong
As the following assembly code:
Examples
nop
nop
ROR R4, R5, R6 ; Rotate right by the value in the bottom byte of R6
nop
nop
You can use the MCUXPresso tools to compile the code and download,  in the debugger, check the op code.
Hope it can help you
XiangJun Rong
