CMSIS RTOS RTX from KEIL - MSP/PSP - What is allowed/what is forbidden?
Content originally posted in LPCWare by mysepp on Tue Apr 05 14:04:09 MST 2016
Question is not directly related to LPC4357, but this is the controller I am using.
I am using CMSIS RTOS RTX from KEIL. There the system runs in MSP/PSP.
Has someone deeper knowledge about MSP/PSP. What is allowed the execute? What is forbidden?
e.g. how about peripheral access? Or GPDMA usage?
Can switch PSP usage off, e.g. when doing critical things like a bootloader/FW update,
where I want to control all things by my own?
I have seen os_set_env, which seem to disable PSP completely.
When and how to call it? Before RTOS is started at all, so I must add it in startup files?
bump
Content originally posted in LPCWare by vtw.433e on Wed Apr 06 01:17:44 MST 2016
Your question doesn't make a lot of sense.
MSP/PSP is the stack pointer (Main Stack Pointer and Process Stack Pointer) and has nothing to do with what can be executed/accessed. To find out more information, get a good book on the Cortex architecture. The books by Joseph Yiu are very good.
