CAN configuration
CAN configuration
1,426 次查看
minglunsheng
We are using the CAN interface on the LPC54608. We also use the fsl_can.c/h driver provided with the MCUXpresso SDK 2.5.0. The fsl_mcan.c function MCAN_SetMsgRAMBase(),MCAN_SetRxFifo0Config(),MCAN_SetTxBufferConfig().
I want to know how much memory MsgRAM will be allocated. And rxFifo0.elementSize ?  txBuffer.dedicatedSize?
Do you have  CAN configuration relevant instructions?
thanks
alun
1,364 次查看
Hello minglun sheng
There is CAN demo under SDK package, you can refer it:
\SDK_2.6.0_LPCXpresso54608\boards\lpcxpresso54608\driver_examples\mcan
And recommend you use the latest version SDK v2.6, download from:
https://mcuxpresso.nxp.com/en/builder
TIC
