Board files for lpc4357-xplorer++
lpcware
Content originally posted in LPCWare by DaddyBurger on Thu Aug 14 15:26:09 MST 2014
Does anyone have the LPCOpen board files for a NGX lpc4357-xplorer++ they can share?
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri Aug 15 10:44:57 MST 2014
LPCOpen is designed to be easy to port to new boards to enable customers to easily support their own custom boards, or for 3rd parties to provide the ports for their customers.
Therefore, I suggest that you start by contacting your board supplier to see if they have a port available. Failing that, you will need to create your own. This is often achieved by starting from the definition for an existing (similar) board. I don't know the details of the NGX Xplorer++ board, but it may be similar enough to the NGX LPC4330 Xplorer board that we do support, for you to use that as a starting point.
There is an FAQ covering carrying out such ports available from:
http://www.lpcware.com/content/faq/how-do-i-port-lpcopen-new-baord
The complete list of LPC43xx boards that we support directly can be found here:
http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc43xx-packages
LPCXpresso Support
