About LPCXpresso Compatibility issues.
niupi_plus
Whether LPCXpresso supports the lib library files generated by keil, some of our files are encrypted into lib format, which are generated by the keil tool, and at present, calling the relevant lib file will prompt that the function is not defined.
Harry_Zhang
Hi @niupi_plus
Keil .lib files are not compatible with LPCUXpresso because of different compilers.
Harry
Harry_Zhang
Hi @niupi_plus
Harry
niupi_plus
OK, I understand now. Thank you.
