I have some questions, I hope somebody could help me.
Question 1:
About hardware by UART; I just need ISP pins(PIO0_6, PIO0_5 & PIO0_4) and RESET pin to handler it?
Question 2:
I suppose I need a reset and active (PIO0_6, PIO0_5 & PIO0_4 -> HIGH, HIGH, LOW) to entry to bootloader right?
Question 3:
In MCU Bootloader v2.5.0 Reference Manual is mentioned "void run_bootloader(void * arg)" function as a way to go to bootloader, it means it coud be called in my user application for example from a serial command from a master MCU to LPC54018?
Question 4:
If the last question is right, I suppose I do not have to set ISP pin (PIO0_6, PIO0_5 & PIO0_4 -> HIGH, HIGH, LOW) to keep it in bootloader section? (This is to left these pin unused and command it from user application).
Question 5:
I knew that bootloader is a factory feature, so, why it comes with the SDK? Do I have to flash it anyway?
Thanks.
Best Regards
Hello Oscar Niño ,
Question 1:
-> Do you mean enter ISP_UART mode? If yes, you are right.
Question 2:
-> Yes, this is entry bootloader (ROM bootloader).
Question 3:
-> NO.
Question 4:
-> The MCU Bootlaoder v2.5.0 is not the same with ROM bootloader, there isn't any relationship .
Question 5:
-> The ROM bootloader is a factory feature, while the MCU Bootloader under SDK is open source bootloader,
customer can use it and also can development another bootloader refer to this code.
Hope it helps,
TIC
Thanks for Reply Alice_Yang
Is there a bootloader for this board that I could use for create my own bootloader? I mean: I need to create a bootloader by UART without using any pins active. For example:
After reset, LPC54018 waits one second before go to user application. After this for example go to check an specific flash address to know if there is a user application, if yes, go to user application, if not keeps on bootloader waiting for a command to start to write flash with valid user application.
Could you help me?
Best Regards
Hello Oscar,
The official bootloader for this chip, there is only MCU bootloader under SDK.
TIC
Thanks for reply Alice_Yang, please could you tell me in which document I can find Flash APIs for this chip?
Helo Oscar,
There is no internal Flash in LPC54018, which Flash APIs do you meaning?
ALice
Hi Alice_Yang
Yes this is a flashless device, I mean functions that I could use to write packets of data on external flash to update firmware(custom bootloader). I'm trying to undersatand flashloader from SDK to create a custom bootloader but it could be more ease if I would know the functions that are used to access external flash.
Best Regards
Hello Oscar,
About the bootloader of SDK, you can find the Flash APIs in spifi_nor folder and spifi :
And there also a simple Flashdrivers example under MCUXprsso IDE if you installed it :
MCUXpressoIDE_11.0.0_2516\ide\Examples\Flashdrivers\NXP\LPC5460x\LPC5460x_lpcspifilib_driver.zip
TIC
