AN12327SW dualbootloader
1,422 次查看
zhangeh10594
In AN12327SW‘s  folder ,when I was double click the post_build_mdk.bat,and it caused an error,like this :
Incorrect image signature.I don't know why this mistake happened,so I want to ask you how to solve this problem.
And after that ,I continue with the instructions above for AN12327.Probably because of the mistake above,when I was excuting  the file of flash_program.bat,it also causes a mistake like this.
ERROR:UartPeripheral() can not open PC UART port (COM4) ,speed(57600hz).
I believe this mistake was caused by the mistake above。So I want to know how to solve the problem above, thank you very much!
标记 (1)
1,330 次查看
ZhangJennie
Which bin file do you work with? can you please test the original dsbl_app.bin file under the AN?
Have a nice day,
Jun Zhang
