ADC Frequency and Sample rate in LPC55xx
ソリューションへジャンプ
1,529件の閲覧回数
pejo
Hi!
I'm configuring ADC Conversion in my LPC5504.
Currently the configuration is the following:
* Main Clock: 96MHz
* ADCK Configuration:
  - CLOCK_SetClkDiv to Prescaler = 2   (48MHz)
* 10 conversion operations:
  - 9 with 35 ADCK cycles total sample time
  - 1 with  131 ADCK cycles total sample time
* Conversion start trigger:
  - Callback function in PWM at 10KHz
This is already working.
In the document from the NXP Knowledge base "ADC multi-channel sampling and DMA transfer in LPC55xx" it is said that maximum frequency is 24MHz but as I said we selected ADCK to 48MHz.
Question #1 Should we set a smaller prescaler (4 instead) according to this limitation or we could even use prescaler=1 ?
In this same document and in the user manual it is said that maximum sample conversion is 1 Mega samples per second. In our case we are doing 10 conversions at 10kHz which are 100,000 conversions pers second
Question #2 should I understand that we are still under the limitation of 1MSPS ?
1,447件の閲覧回数
Hello @pejo
For details about the ADC clock frequency and sample rate, please refer to the Datasheet.
Thank you.
Alice
1,448件の閲覧回数
Hello @pejo
Thank you.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2254173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55xx%E3%81%AEADC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3ELPC5504%20%E3%81%A7%20ADC%20%E5%A4%89%E6%8F%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3CSTRONG%3E%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3C%2FSTRONG%3E%EF%BC%9A96MHz%3C%2FP%3E%3CP%3E*%20%3CSTRONG%3EADCK%E6%A7%8B%E6%88%90%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E-%20%3CSPAN%3ECLOCK_SetClkDiv%20%E3%82%92%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%20%3D%202%20(48MHz)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E*%20%3CSTRONG%3E10%E5%9B%9E%E3%81%AE%E5%A4%89%E6%8F%9B%E6%93%8D%E4%BD%9C%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E5%90%88%E8%A8%88%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%99%82%E9%96%9335ADCK%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A79%3C%2FP%3E%3CP%3E-%201%20131%20ADCK%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E5%90%88%E8%A8%88%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%99%82%E9%96%93%3C%2FP%3E%3CP%3E*%3CSTRONG%3E%E5%A4%89%E6%8F%9B%E9%96%8B%E5%A7%8B%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E-%2010KHz%E3%81%AEPWM%E3%81%A7%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E9%96%A2%E6%95%B0%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ENXP%20%E3%83%8A%E3%83%AC%E3%83%83%E3%82%B8%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%8C%20%3CSPAN%3ELPC55xx%20%E3%81%A7%E3%81%AE%20ADC%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A8%20DMA%20%E8%BB%A2%E9%80%81%E3%80%8D%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E5%A4%A7%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%2024%20MHz%20%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81ADCK%20%E3%82%92%2048%20MHz%20%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%20%231%20%E3%81%93%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%84%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%A9%20(%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%204)%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%20prescaler%3D1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%90%8C%E3%81%98%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E5%A4%A7%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E5%A4%89%E6%8F%9B%E3%81%AF%201%20%E7%A7%92%E3%81%82%E3%81%9F%E3%82%8A%201%20%E3%83%A1%E3%82%AC%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%BF%B0%E3%81%B9%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AECASE%E3%81%A7%E3%81%AF%E3%80%8110kHz%E3%81%A710%E5%9B%9E%E3%81%AE%E5%A4%89%E6%8F%9B%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF1%E7%A7%92%E3%81%82%E3%81%9F%E3%82%8A10%E4%B8%87%E5%9B%9E%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%AB%E7%9B%B8%E5%BD%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%202%3A%20%E3%81%BE%E3%81%A0%201MSPS%20%E3%81%AE%E5%88%B6%E9%99%90%E5%86%85%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2254173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ADC%20Frequency%20and%20Sample%20rate%20in%20LPC55xx%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232719%22%20target%3D%22_blank%22%3E%40pejo%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3EADC%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1765166017884.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1765166017884.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368868i038CFE73E812CF93%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1765166017884.png%22%20alt%3D%22Alice_Yang_0-1765166017884.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%AA%E3%82%B9%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
