9-bit UART communication for LPC4078
michelle2022
I am using LPC4078 microcontroller and I need to integrate the UART device which is receiving 9-bit.
I couldn't find a register that enables 9-bit UART communication in the user manual or library API code.
Does LPC4078 support 9-bit UART comm? If yes, please provide guidance on which register to use.
Thank you
Michelle
Tags (3)
EdwinHz
Hi @michelle2022,
Unfortunately, the LPC4078 does not support 9-bit UART communication. As you can see from the "Features" section of each of the UART chapters, the LPC4078's UARTs only support 5, 6, 7, and 8 data sizes.
Sorry for the inconvenience this may cause.
BR,
Edwin.
michelle2022
Hi Edwin,
In addition, I found several points that seem to support 9-bit mode in the document.
Is there a work-around method to transmit 9-bit through UART1 ?
Thank you
Michelle
EdwinHz
Hi @michelle2022,
The 9th bit in this case is just for the auto address detection feature, not for transmitting 9-bit data size frames. The explanation of this feature is described on section "17.5.21 RS-485/EIA-485 modes of operation" of the User Guide.
BR,
Edwin.
michelle2022
Hi Edwin,
Thanks for clarifying.
But, I can see the comment of "9-bit enable" in the RS485CTRL register description for AAD mode.
Could you let me know what it means?
Thank you
Michelle
EdwinHz
Hi @michelle2022,
BR,
Edwin.
