24 channel PWM from a LPC1549 QFP100 (using SCT), a working solution if anyone can use it :)
1,101 次查看
lpcware
Content originally posted in LPCWare by cgroen on Fri Jan 08 04:10:33 MST 2016
I see a number of questions regarding using the SCT for generating PWM. I have a board with 24 PWM outputs (driving servos) and I thought someone else might find use of my code. I have attached two files, PWM.h and PWM,c. Code should be pretty much sef-explanatory.
Anyway, feel free to use this for whatever you see fit :)
Original Attachment has been moved to: PWM.H.zip
Original Attachment has been moved to: PWM.C.zip
962 次查看
lpcware
Content originally posted in LPCWare by cgroen on Fri Jan 08 08:58:22 MST 2016
Forgot to add, using LPCOpen!
