SCTimer implement traffic signal
Overview
     The State Configurable Timer (SCTimer/PWM) is a peripheral that is unique to NXP Semiconductors. It can operate like most traditional timers, but also adds a state machine to give it a higher degree of configurability and control, in another word, the SCTimer/PWM can be considered as consist of Stand Timer and State/Event Logic (Fig 1). This allows the SCT to be configured as multiple PWMs, a PWM with dead-time control, and a PWM with reset capability, in addition to many other configurations that can’t be duplicated with traditional timers. Once the SCTimer/PWM has been configured, it can run autonomously from the microcontroller core, unless the SCTimer/PWM interrupt has been enabled which requires the core to service the interrupt.
Fig 1
      The first time you look at the SCTimer/PWM, it may appear to be a very complex peripheral, but you will see that it is actually not that difficult to use. Understanding the Event and State is critical to understanding the SCTimer/PWM.
       Event:
       The following conditions define possible events: a counter match condition, an input (or output) condition, a combination of a match and/or an input/output condition in a specified state, and the count direction. Events can control outputs, interrupts, DMA requests and the SCTimer/PWM states. They can also cause timer limit, halt, start, or stop conditions to occur.
       State:
        The state variable is the main feature that distinguishes the SCTimer/PWM from other counter/timer/PWM blocks. Events can be made to occur only in certain states. Events, in turn, can perform the following actions:
a)    Set and clear outputs;
b)   Limit, stop, and start the counter;
c)    Cause interrupts;
d)   Modify the state variable;
        Regarding the event and state mechanism (Fig 2 show a basic example), The SCT allows the user to group and filter events, thereby selecting some events to be enabled together while others are disabled. A group of enabled and disabled events can be described as a state, and several states with different sets of enabled and disabled events are allowed. Changing from one state to another is event driven as well and can happen without software intervention. Formally, the SCTimer/PWM can be programmed as state machine generator. The ability to perform switching between groups of events provides the SCT the unique capability to be utilized as a highly complex State Machine engine. Events identify the occurrence of conditions that warrant state changes and determine the next state to move to. This provides an extremely powerful control tool - particularly when the SCT inputs and outputs are connected to other on-chip resources (comparators, ADC triggers, other timers etc.) in addition to general-purpose I/O.
Fig 2
Traffic signal implementation
            Fig 3 illustrates the application of the SCT to simulate the traffic signal.
Fig 3
v Demo create
        LPCOpen is an extensive collection of free software libraries (drivers and middleware) and example programs that enable developers to create multifunctional products based on LPC microcontrollers. In this article, I will illustrate the steps of creating a new demo in the LPCOpen, for instance, create a demo by using the IAR IDE. Since the selected hardware board is the LPCXpresso824, the creating work is based on the corresponding LPCOpen.
  1.              Creates a new project
Fig 4
2.    Create the example and lib groups, then add the startup and board initialization files under the example group and add the library files: board_nxp_lpcxpresso_824.a and chip_82x_lib.a under the lib group. Next, create a main.c file: traffic_signal_demo.c.
Fig 5
3.     Add the corresponding paths
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_chip\chip_8xx\config_82x
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_chip\chip_common
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_board\board_common
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_board\boards_8xx\nxp_lpcxpresso_824
               $PROJ_DIR$\..\..\..\..\..\..\software\CMSIS\CMSIS\Include
4.     Miscellaneous settings
For instance, target selecting, adds the linker file, add other c files (Fig 6),etc.
Fig 6
v Crucial code
                                                         Table 1 main.c
 * @brief             Application main program
 * @return          Nothing (This function will not return)
int main(void)
                /* Generic Initialization */
                SystemCoreClockUpdate();
                /*Set system clock div as 30*/
                Chip_Clock_SetSysClockDiv(30);
                /*Assign SCT_out to board LED pin*/
                Chip_SWM_MovablePinAssign(SWM_SCT_OUT1_O, 13); // assign SCTOUT_0 to P0_13 YELLOW_LED
                Chip_SWM_MovablePinAssign(SWM_SCT_OUT2_O, 27); // assign SCTOUT_0 to P0_27 GREEN_LED
                Chip_SWM_MovablePinAssign(SWM_SCT_OUT0_O, 17); // assign SCTOUT_0 to P0_17 RED_LED
                /* Initialize the SCT clock and reset the SCT */
                Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_SCT);
                Chip_SYSCTL_PeriphReset(RESET_SCT);
                /*Initialize SCT*/
                sct_fsm_init();
                /* Start the SCT counter by clearing Halt_L in the SCT control register */
                Chip_SCT_ClearControl(LPC_SCT, SCT_CTRL_HALT_L);
             /* Enter sleep mode */
                while (1) {
                                __WFI();
                                                    Table 2 sct_fsm_init(void)
void sct_fsm_init (void)
/*The SCT operates as a unified 32-bit counter*/
LPC_SCT->CONFIG = (LPC_SCT->CONFIG & ~0x00060001) | 0x00000001; /* UNIFIED */
/* MATCH/CAPTURE registers */
LPC_SCT->REGMODE_L = 0x00000000;
LPC_SCT->MATCH[0].U = entry_mat;             /* entry_match */
LPC_SCT->MATCHREL[0].U = entry_mat;
LPC_SCT->MATCH[1].U = flash;                       /* flash_mat0 */
LPC_SCT->MATCHREL[1].U = flash;
LPC_SCT->MATCH[2].U = flash1;                    /* flash_mat1 */
LPC_SCT->MATCHREL[2].U = flash1;
LPC_SCT->MATCH[3].U = delay;                     /* match0 */
LPC_SCT->MATCHREL[3].U = delay;
LPC_SCT->MATCH[4].U = yel_delay;              /* yel_delay_mat */
LPC_SCT->MATCHREL[4].U = yel_delay;
LPC_SCT->MATCH[5].U = yel_flash;               /* yel_flash_mat */
LPC_SCT->MATCHREL[5].U = yel_flash;
/* OUTPUT registers */
/*Event 1 set the output*/
LPC_SCT->OUT[5].SET = 0x00000002;        /* out_track */
/*Event 3 clear the output*/
LPC_SCT->OUT[5].CLR = 0x00000008;
/*Event 0 and 3 set the output*/
LPC_SCT->OUT[2].SET = 0x00000009;        /* turn_green */
/*Event 7 clear the output*/
LPC_SCT->OUT[2].CLR = 0x00000080;
LPC_SCT->OUT[0].SET = 0x00000002;        /* turn_red */
/*Event 0 and 6 clear the output*/
LPC_SCT->OUT[0].CLR = 0x00000041;
/*Event 0, 2, 4, 5, 6 and 7 set the output*/
LPC_SCT->OUT[1].SET = 0x000000F5;        /* turn_yellow */
/*Event 1, 3, 4, 5 set the output*/
LPC_SCT->OUT[1].CLR = 0x0000003A;
  /* Unused outputs must not be affected by any event */
LPC_SCT->OUT[3].SET = 0;
LPC_SCT->OUT[3].CLR = 0;
LPC_SCT->OUT[4].SET = 0;
LPC_SCT->OUT[4].CLR = 0;
/* Conflict resolution register */
LPC_SCT->RES = (LPC_SCT->RES & ~0x0000000C) | 0x0000000C;
 Set COMBMODE = 0x1. Event 0 uses match condition only.
 Set MATCHSEL = 0x0. Select match value of match register 0.
The match value of MAT0 is associated with event 0
Set STATEV bits to 1 and the STATED bit to 1. Event 0 changes the
state to state 1
LPC_SCT->EV[0].CTRL = 0x0000D000;     /* U: --> state RED */
LPC_SCT->EV[0].STATE = 0x00000001;
 Set COMBMODE = 0x1. Event 1 uses match condition only.
 Set MATCHSEL = 0x3. Select match value of match register 3.
The match value of MAT3 is associated with event 1
Set STATEV bits to 2 and the STATED bit to 1. Event 1 changes the
state to state 2
LPC_SCT->EV[1].CTRL = 0x00015003;     /* U: --> state YELLOW */
LPC_SCT->EV[1].STATE = 0x00000002;
 Set MATCHSEL = 0x4. Select match value of match register 4.
The match value of MAT4 is associated with event 2
Set STATEV bits to 4 and the STATED bit to 1. Event 1 changes the
state to state 4
LPC_SCT->EV[2].CTRL = 0x00025004;     /* U: --> state YELLOW_FLASH */
LPC_SCT->EV[2].STATE = 0x00000004;
The match value of MAT3 is associated with event3
state to state 2
LPC_SCT->EV[3].CTRL = 0x00015003;     /* U: --> state YELLOW */
LPC_SCT->EV[3].STATE = 0x00000008;
 Set COMBMODE = 0x3. Event 6 uses when match and I/O condition occur.
 Set MATCHSEL = 0x5. Select match value of match register 5.
Set OUTSEL = 1. Select output.
Set IOSEL = 5. Select output 5.
Set IOCOND = 0x0. Output 0 is Low
The match value of MAT5 is associated with event 6
Set STATEV bits to 1 and the STATED bit to 1. Event 1 changes the
state to state 1
LPC_SCT->EV[6].CTRL = 0x0000F165;     /* U: --> state RED */
LPC_SCT->EV[6].STATE = 0x00000010;
Set IOCOND = 0x3. Output 0 is High
The match value of MAT5 is associated with event 7
Set STATEV bits to 3 and the STATED bit to 1. Event 7 changes the
state to state 3
LPC_SCT->EV[7].CTRL = 0x0001FD65;     /* U: --> state GREEN */
LPC_SCT->EV[7].STATE = 0x00000010;
 Set MATCHSEL = 0x1. Select match value of match register 1.
The match value of MAT1 is associated with event4
state to state 4
LPC_SCT->EV[4].CTRL = 0x00025001;     /* U: --> state YELLOW_FLASH */
LPC_SCT->EV[4].STATE = 0x00000010;
 Set MATCHSEL = 0x2. Select match value of match register 2.
The match value of MAT2 is associated with event5
state to state 4
LPC_SCT->EV[5].CTRL = 0x00025002;     /* U: --> state YELLOW_FLASH */
LPC_SCT->EV[5].STATE = 0x00000010;
/* STATE registers */
LPC_SCT->STATE_L = 0;
/* state names assignment: */
  /* State U 0: U_ENTRY */
  /* State U 1: RED */
  /* State U 2: YELLOW */
  /* State U 3: GREEN */
  /* State U 4: YELLOW_FLASH */
/* CORE registers */
LPC_SCT->START_L = 0x00000000;
LPC_SCT->STOP_L =  0x00000000;
LPC_SCT->HALT_L =  0x00000000;
/* Event0, 1, 2, 3, 6 and 7 reset the counter register */
LPC_SCT->LIMIT_L = 0x000000CF;
LPC_SCT->EVEN =    0x00000000;
LPC_SCT->DMAREQ0 = 0x00000000;
LPC_SCT->DMAREQ1 = 0x00000000;
v Result demonstrate
         The demo runs on the LPCXpresso824-MAX board, and using the Blue led replaces the Yellow led, and the video shows the demo working.
Fig 7 LPCXpresso824-MAX board
Video's link:
SCTimer implement traffic signal - YouTube
添付
コメント
I'm new to this kind of programming and this environment. I do understand  that you are assigning GPIO pins to the SWM_CTL_OUT, but how do you get these hex values to talk to the actual pins? Because I'm working on an LPC824 and I try to toggle GPIO_17 on event 0, and this seems to fail.
%3CLINGO-SUB%20id%3D%22lingo-sub-1105508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESCTimer%E3%81%AF%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E6%A9%9F%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2024.0pt%3B%22%3ESCTimer%E3%81%AF%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E6%A9%9F%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-380638743%22%20id%3D%22toc-hId-1303201619%22%3EOverview%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EState%20Configurable%20Timer(SCTimer%2FPWM)%E3%81%AF%E3%80%81NXP%20Semiconductors%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E5%BE%93%E6%9D%A5%E3%81%AE%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E5%BA%A6%E3%81%AA%E6%A7%8B%E6%88%90%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%A8%E5%88%B6%E5%BE%A1%E6%80%A7%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81SCTimer%2FPWM%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%A8%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%2F%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A6%8B%E3%81%AA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(%E5%9B%B31)%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SCT%E3%82%92%E8%A4%87%E6%95%B0%E3%81%AEPWM%E3%80%81%E3%83%87%E3%83%83%E3%83%89%E3%82%BF%E3%82%A4%E3%83%A0%E5%88%B6%E5%BE%A1%E4%BB%98%E3%81%8DPWM%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%A9%9F%E8%83%BD%E4%BB%98%E3%81%8DPWM%E3%81%AA%E3%81%A9%E3%80%81%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9E%E3%81%A7%E3%81%AF%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BB%96%E3%81%AE%E5%A4%9A%E3%81%8F%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82SCTimer%2FPWM%E3%82%92%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81SCTimer%2FPWM%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E3%82%B3%E3%82%A2%E3%81%8C%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%B3%E3%82%A2%E3%81%8B%E3%82%89%E8%87%AA%E5%BE%8B%E7%9A%84%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20577px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3042iE8B664220B6F695B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9B%B31%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ESCTimer%2FPWM%E3%82%92%E5%88%9D%E3%82%81%E3%81%A6%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%A4%87%E9%9B%91%E3%81%AA%E5%91%A8%E8%BE%BA%E6%A9%9F%E5%99%A8%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E4%BD%BF%E3%81%84%E3%81%AB%E3%81%8F%E3%81%84%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%A8%E7%8A%B6%E6%85%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81SCTimer%2FPWM%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200in%3B%22%20id%3D%22toc-hId-1071200217%22%20id%3D%22toc-hId-1993763093%22%3E%E5%87%BA%E6%9D%A5%E4%BA%8B%EF%BC%9A%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%AC%A1%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AF%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%80%81%E5%85%A5%E5%8A%9B%20(%E3%81%BE%E3%81%9F%E3%81%AF%E5%87%BA%E5%8A%9B)%20%E6%9D%A1%E4%BB%B6%E3%80%81%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%E7%8A%B6%E6%85%8B%E3%81%AE%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%A8%E5%85%A5%E5%8A%9B%2F%E5%87%BA%E5%8A%9B%E6%9D%A1%E4%BB%B6%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E6%96%B9%E5%90%91%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E5%87%BA%E5%8A%9B%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%80%81DMA%E8%A6%81%E6%B1%82%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3SCTimer%2FPWM%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%88%B6%E9%99%90%E3%80%81%E5%81%9C%E6%AD%A2%E3%80%81%E9%96%8B%E5%A7%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%81%9C%E6%AD%A2%E6%9D%A1%E4%BB%B6%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200in%3B%22%20id%3D%22toc-hId--736254246%22%20id%3D%22toc-hId-186308630%22%3E%E7%8A%B6%E6%85%8B%EF%BC%9A%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E5%A4%89%E6%95%B0%E3%81%AF%E3%80%81SCTimer%2FPWM%E3%82%92%E4%BB%96%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%2F%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%2FPWM%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E5%8C%BA%E5%88%A5%E3%81%99%E3%82%8B%E4%B8%BB%E8%A6%81%E3%81%AA%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AE%E3%81%BF%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--45692772%22%20id%3D%22toc-hId-876870104%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Ea)%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--1853147235%22%20id%3D%22toc-hId--930584359%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Eb)%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E5%88%B6%E9%99%90%E3%80%81%E5%81%9C%E6%AD%A2%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId-634365598%22%20id%3D%22toc-hId-1556928474%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Ec)%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--1173088865%22%20id%3D%22toc-hId--250525989%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Ed)%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E7%8A%B6%E6%85%8B%E5%A4%89%E6%95%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%A8%E7%8A%B6%E6%85%8B%E3%81%AE%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0(%E5%9B%B32%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E4%BE%8B)%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81SCT%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%81%97%E3%81%A6%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E3%81%BE%E3%81%A8%E3%82%81%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%A8%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E7%8A%B6%E6%85%8B%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%98%E8%BF%B0%E3%81%A7%E3%81%8D%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%A8%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8C%81%E3%81%A4%E8%A4%87%E6%95%B0%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8B%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%88%A5%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%B8%E3%81%AE%E5%A4%89%E5%8C%96%E3%82%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E9%A7%86%E5%8B%95%E5%9E%8B%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BB%8B%E5%85%A5%E3%81%AA%E3%81%97%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E5%BC%8F%E3%81%AB%E3%81%AF%E3%80%81SCTimer%2FPWM%E3%81%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%82%B8%E3%82%A7%E3%83%8D%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E9%96%93%E3%81%A7%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SCT%20%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%A4%87%E9%9B%91%E3%81%AA%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20%E3%83%9E%E3%82%B7%E3%83%B3%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E7%8B%AC%E8%87%AA%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E7%8A%B6%E6%85%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%99%E3%82%8B%E6%9D%A1%E4%BB%B6%E3%81%AE%E7%99%BA%E7%94%9F%E3%82%92%E8%AD%98%E5%88%A5%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E7%8A%B6%E6%85%8B%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E7%89%B9%E3%81%ABSCT%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E5%87%BA%E5%8A%9B%E3%81%8C%E6%B1%8E%E7%94%A8I%2FO%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E4%BB%96%E3%81%AE%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9(%E3%82%B3%E3%83%B3%E3%83%91%E3%83%AC%E3%83%BC%E3%82%BF%E3%80%81ADC%E3%83%88%E3%83%AA%E3%82%AC%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AA%E3%81%A9)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BC%B7%E5%8A%9B%E3%81%AA%E5%88%B6%E5%BE%A1%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20988px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111687i87D39EC2AFBCC826%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B32%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-613359390%22%20id%3D%22toc-hId-1535922266%22%3E%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E6%A9%9F%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FH1%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9B%B33%E3%81%AF%E3%80%81%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AESCT%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20873px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111686i6F23EF30668C3A09%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B33%3C%2FP%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId-1303920864%22%20id%3D%22toc-hId--2068483556%22%3Ev%20%E3%83%87%E3%83%A2%E4%BD%9C%E6%88%90%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ELPCOpen%E3%81%AF%E3%80%81%E9%96%8B%E7%99%BA%E8%80%85%E3%81%8CLPC%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%A4%9A%E6%A9%9F%E8%83%BD%E8%A3%BD%E5%93%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA(%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2)%E3%81%A8%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%BA%83%E7%AF%84%E3%81%AA%E3%82%B3%E3%83%AC%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81LPCOpen%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%A2%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0IAR%20IDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%A2%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Flpcxpresso-boards%2Flpcxpresso824-max-board-for-lpc82x-family-mcus%3AOM13071%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3ELPCXpresso824%3C%2FSPAN%3E%3C%2FA%3E%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BD%9C%E6%88%90%E4%BD%9C%E6%A5%AD%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8BLPCOpen%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%20style%3D%22text-indent%3A%20-.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%20style%3D%22width%3A%20316px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111685i348148EBC4A3C9C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_19.png%22%20alt%3D%22pastedImage_19.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B34%3C%2FP%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--503533599%22%20id%3D%22toc-hId-419029277%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E2.%20example%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A8%20lib%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%9C%E3%83%BC%E3%83%89%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20example%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E4%B8%8B%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(lib%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97)%20board_nxp_lpcxpresso_824.a%20%E3%81%A8%20chip_82x_lib.a%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81main.c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20traffic_signal_demo.c%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%20style%3D%22width%3A%20413px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111684iBF86A700906FC467%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_22.png%22%20alt%3D%22pastedImage_22.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B35%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%203.%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%91%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_chip%5Cchip_8xx%5Cconfig_82x%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_chip%5Cchip_common%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_chip%5Cchip_8xx%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_board%5Cboard_common%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5C%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%5Clpc_core%5Clpc_board%5Cboards_8xx%5Cnxp_lpcxpresso_824%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5C%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%5CCMSIS%5CCMSIS%5C%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%204.%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E9%81%B8%E6%8A%9E%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%80%81%E4%BB%96%E3%81%AEc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%BF%BD%E5%8A%A0(%E5%9B%B36)%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_40.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_40.png%22%20style%3D%22width%3A%20255px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F24866iEAFD234BF5B020CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_40.png%22%20alt%3D%22pastedImage_40.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9B%B36%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--637218323%22%20id%3D%22toc-hId-285344553%22%3Ev%20Crucial%E3%82%B3%E3%83%BC%E3%83%89%3C%2FH2%3E%3CP%3E%E8%A1%A8%201%20main.c%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E*%20%40brief%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E*%20%40return%E3%81%AA%E3%81%97(%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AF%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3Eint%20main(void)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E6%B1%8E%E7%94%A8%E5%88%9D%E6%9C%9F%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SystemCoreClockUpdate()%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AFdiv%E3%82%9230%E3%81%AB%E8%A8%AD%E5%AE%9A*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Chip_Clock_SetSysClockDiv(30)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%83%9C%E3%83%BC%E3%83%89LED%E3%83%94%E3%83%B3%E3%81%ABSCT_out%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SWM_MovablePinAssign(SWM_SCT_OUT1_O%E3%80%8113)%3BP0_13%20YELLOW_LED%E3%81%B8%E3%81%AESCTOUT_0%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SWM_MovablePinAssign(SWM_SCT_OUT2_O%E3%80%8127)%3BP0_27%20GREEN_LED%E3%81%B8%E3%81%AESCTOUT_0%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SWM_MovablePinAssign(SWM_SCT_OUT0_O%E3%80%8117)%3BP0_17%20RED_LED%E3%81%B8%E3%81%AESCTOUT_0%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20SCT%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81SCT%20%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_Clock_EnablePeriphClock(SYSCTL_CLOCK_SCT)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SYSCTL_PeriphReset(RESET_SCT)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*SCT%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sct_fsm_init()%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20SCT%E5%88%B6%E5%BE%A1%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AEHalt_L%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6SCT%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%82%92%E9%96%8B%E5%A7%8B%20*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SCT_ClearControl(LPC_SCT%E3%80%81SCT_CTRL_HALT_L)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E(1)%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20__WFI()%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Table%202%20sct_fsm_init(void)%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3Evoid%20sct_fsm_init%20(void)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*SCT%E3%81%AF%E7%B5%B1%E4%B8%80%E3%81%95%E3%82%8C%E3%81%9F32%E3%83%93%E3%83%83%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BCONFIG%20%3D%20(LPC_SCT-%26gt%3BCONFIG%20%26amp%3B%20~0x00060001)%20%7C0x00000001%3B%2F*%E3%83%A6%E3%83%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%89*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20MATCH%2FCAPTURE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BREGMODE_L%20%3D%200x00000000%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B0%5D.U%20%3D%20entry_mat%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20entry_match%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B0%5D.U%20%3D%20entry_mat%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B1%5D.U%20%3D%20flash%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*%20flash_mat0%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT%20-%20%26gt%3B%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%83%AB%5B1%5D%E3%80%82U%20%3D%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B2%5D.U%20%3D%20flash1%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*%20flash_mat1%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%83%AB%5B2%5D%E3%80%82U%20%3D%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E8%A9%A6%E5%90%88%5B3%5D%E3%80%82U%20%3D%20%E9%81%85%E5%BB%B6%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*%20%E3%83%9E%E3%83%83%E3%83%810%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT%20-%20%26gt%3B%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%83%AB%5B3%5D%E3%80%82U%20%3D%20%E9%81%85%E5%BB%B6%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E8%A9%A6%E5%90%88%5B4%5D%E3%80%82U%20%3D%20yel_delay%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20yel_delay_mat%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%83%AB%5B4%5D%E3%80%82U%20%3D%20yel_delay%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B5%5D.U%20%3D%20yel_flash%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%2F*%20yel_flash_mat%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT%20-%20%26gt%3B%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%83%AB%5B5%5D%E3%80%82U%20%3D%20yel_flash%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20OUTPUT%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B5%5D%E3%80%82%E3%82%BB%E3%83%83%E3%83%88%20%3D%200x00000002%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20out_track%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%203%20%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B5%5D%E3%80%82CLR%20%3D%200x00000008%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%200%20%E3%81%A8%203%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B2%5D%E3%80%82%E3%82%BB%E3%83%83%E3%83%88%20%3D%200x00000009%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20turn_green%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%887%E3%81%AF%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B2%5D%E3%80%82CLR%20%3D%200x00000080%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B0%5D%E3%80%82%E3%82%BB%E3%83%83%E3%83%88%20%3D%200x00000002%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20turn_red%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%200%20%E3%81%A8%206%20%E3%81%AF%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B0%5D%E3%80%82CLR%20%3D%200x00000041%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%880%E3%80%812%E3%80%814%E3%80%815%E3%80%816%E3%80%817%E3%81%8C%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B1%5D%E3%80%82%E3%82%BB%E3%83%83%E3%83%88%20%3D%200x000000F5%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20turn_yellow%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%E3%80%813%E3%80%814%E3%80%815%20%E3%81%8C%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B1%5D%E3%80%82CLR%20%3D%200x0000003A%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%82%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B3%5D%E3%80%82%E3%82%BB%E3%83%83%E3%83%88%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B3%5D%E3%80%82CLR%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B4%5D%E3%80%82%E3%82%BB%E3%83%83%E3%83%88%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E3%82%A2%E3%82%A6%E3%83%88%5B4%5D%E3%80%82CLR%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E7%AB%B6%E5%90%88%E8%A7%A3%E6%B1%BA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BRES%20%3D%20(LPC_SCT-%26gt%3BRES%20%26amp%3B%20~0x0000000C)%20%7C0x0000000C%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%200%20%E3%81%AF%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x0%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%200%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MAT0%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%E3%80%81%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%200%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%200%20%E3%81%AF%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%201%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B0%5D%E3%80%82Ctrl%20%3D%200x0000D000%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20RED%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B0%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000001%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%AF%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x3%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%203%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MAT3%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%E3%80%81%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%202%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%202%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B1%5D%E3%80%82Ctrl%20%3D%200x00015003%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20YELLOW%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B1%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000002%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%AF%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x4%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%204%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MAT4%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%202%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%204%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%204%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B2%5D%E3%80%82CTRL%20%3D%200x00025004%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B2%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000004%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%AF%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x3%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%203%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MAT3%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%20event3%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%202%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%202%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B3%5D%E3%80%82Ctrl%20%3D%200x00015003%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20YELLOW%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B3%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000008%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x3%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%206%20%E3%81%AF%E3%80%81%E4%B8%80%E8%87%B4%E3%81%A8%20I%2FO%20%E6%9D%A1%E4%BB%B6%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x5%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%205%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3EOUTSEL%20%3D%201%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3EIOSEL%20%3D%205%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%205%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20IOCOND%20%3D%200x0%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%200%20%E3%81%AF%20Low%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%20MAT5%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%E3%80%81%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%206%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%201%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B6%5D%E3%80%82CTRL%20%3D%200x0000F165%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20RED%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B6%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x3%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%206%20%E3%81%AF%E3%80%81%E4%B8%80%E8%87%B4%E3%81%A8%20I%2FO%20%E6%9D%A1%E4%BB%B6%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x5%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%205%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3EOUTSEL%20%3D%201%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3EIOSEL%20%3D%205%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%205%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20IOCOND%20%3D%200x3%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%200%20%E3%81%AF%20High%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%20MAT5%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%E3%80%81%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%207%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%203%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%207%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%203%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B7%5D%E3%80%82CTRL%20%3D%200x0001FD65%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20GREEN%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B7%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%AF%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x1%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%201%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMAT1%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%20event4%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%204%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%204%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B4%5D%E3%80%82Ctrl%20%3D%200x00025001%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B4%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ECOMBMODE%20%3D%200x1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%AF%E4%B8%80%E8%87%B4%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%26nbsp%3BMATCHSEL%20%3D%200x2%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%87%B4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%202%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MAT2%20%E3%81%AE%E4%B8%80%E8%87%B4%E5%80%A4%E3%81%AF%20event5%20%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3ESTATEV%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%204%20%E3%81%AB%E3%80%81STATED%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%201%20%E3%81%A7%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20state%20%E3%81%8B%E3%82%89%20state%204%20%E3%81%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B5%5D%E3%80%82Ctrl%20%3D%200x00025002%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%85%8B%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B5%5D%E3%80%82%E7%8A%B6%E6%85%8B%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20STATE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BSTATE_L%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%85%8B%E5%90%8D%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3A%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20U%200%3A%20U_ENTRY%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20U%201%3A%20%E8%B5%A4%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20U%202%3A%20%E3%82%A4%E3%82%A8%E3%83%AD%E3%83%BC%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20U%203%3A%20%E3%82%B0%E3%83%AA%E3%83%BC%E3%83%B3%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20U%204%3A%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20CORE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BSTART_L%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BSTOP_L%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BHALT_L%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20Event0%2C%201%2C%202%2C%203%2C%206%2C%207%20%E3%81%A7%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BLIMIT_L%20%3D%200x000000CF%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E5%81%B6%E6%95%B0%3D0x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BDMAREQ0%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BDMAREQ1%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId-1850294510%22%20id%3D%22toc-hId--1522109910%22%3Ev%20%E7%B5%90%E6%9E%9C%20%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FH2%3E%3CP%3E%E3%83%87%E3%83%A2%E3%81%AFLPCXpresso824-MAX%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E9%9D%92%E8%89%B2LED%E3%82%92%E9%BB%84%E8%89%B2LED%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E3%83%87%E3%83%A2%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_43.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_43.png%22%20style%3D%22width%3A%20413px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3090i75265F03EEF9DBB9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_43.png%22%20alt%3D%22pastedImage_43.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B37LPCXpresso824-MAX%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3A%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fyoutu.be%2Fwr4VJDaa_OY%22%20title%3D%22https%3A%2F%2Fyoutu.be%2Fwr4VJDaa_OY%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESCTimer%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%20%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%20%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%20-%20YouTube%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ASCTimer%E3%81%AF%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E6%A9%9F%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E7%A8%AE%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E3%81%93%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AB%E4%B8%8D%E6%85%A3%E3%82%8C%E3%81%A7%E3%81%99%E3%80%82GPIO%E3%83%94%E3%83%B3%E3%82%92SWM_CTL_OUT%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AEHEX%E5%80%A4%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%94%E3%83%B3%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AFLPC824%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E3%82%A4%E3%83%99%E3%83%B3%E3%83%880%E3%81%A7GPIO_17%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎10-07-2016 11:55 PM
更新者:
